Conservation of angular momentum
The discussion revolves around the conservation of angular momentum in systems involving rotating masses and the implications when such systems transition to linear motion. Participants explore scenarios involving two masses connected by a line and a planet revolving around a sun, questioning how angular momentum behaves when the system changes.
  • Participants examine the relationship between angular momentum and linear momentum, questioning the conditions under which angular momentum is conserved. Some express confusion about the behavior of angular momentum when the connection between masses is broken, while others suggest simpler scenarios to clarify the concepts.
The discussion is active, with various interpretations being explored. Some participants have offered insights into the definitions and calculations of angular momentum, while others are questioning the foundational principles and relationships between linear and angular momentum. There is no explicit consensus, but productive dialogue is ongoing.
Participants are grappling with the implications of breaking connections in a rotating system and the assumptions underlying angular momentum conservation. There is mention of external resources and examples to support the discussion, but no definitive conclusions have been reached.
Borek
Mentor
Bear with me, I am mathematically challenged chemist.
I am trying to understand following situation:
There are two masses connected with a line. They rotate about an axis perpendicular to the line. System have some easy to calculate angular momentum. In a closed system angular momentum is constant, so as long as we don't touch it, angular momentum is not changing.
Line breaks.
Now we have two masses going in straight lines. Obviously at the moment line broke each mass had some linear momentum and it still has the same linear momentum, tangential to the previous trajectory.
However, I can't see what have happened to the angular momentum. L=rxp - r and p vectors are getting parallel, so the cross product becomes zero.
I suppose I am mising something simple, but I can't see it The only explanation I can think of is that angular momentum conservation is only kind of emergent property of the rotating system, while linear momentum conservation is the 'real' principle, but I feel like that's rather a bold statement.
A similar problem. Just one mass here. A planet revloving around a highly massive sun. There is some initial angular momentum that's unchanged as gravity is central. Now what would happen if gravity is 'switched off'?
The cross product does not become zero! L = r X p = rp sinθ; rsinθ remains constant. (Even though r and θ both change, rsinθ remains constant.)
I have no back of the envelope at hand, so I had to try on the postit note card. Assuming r0 is the distance between rotation axis and the line on which mass moves now
[tex]r \sin \theta = r_0[/tex]
You learn all your life and you die stupid :smile:
The component of r which is perpendicular to p is constant so r x p is constant.
Maybe try considering first a simpler problem.
I have a single massive object moving in space. There are no forces acting on it, and it remains moving at a constant velocity. There is no torque on it, and it is not rotating in any way.
What is its angular momentum with respect to the origin? Does it even have angular momentum? Go back to your formula and figure out what the angular momentum is, given the velocity, mass, and position of the object.
Angular momentum is defined by product of distance and linear momentum,
it doesn't necessarily has to imply rotational movement
in your problem, even when the mass is moving in a straight line, you can
see that the product of distance and momentum remains as before.
I am also of the opinion that linear momentum is more fundamental than angular momentum.
Still, as has been pointed out in earlier messages in this thread, even if there is no centripetal force, sustaining a rotating system, angular momentum can still be defined.
I have attached an image, (I don't know how the approval process works here.) The image comes from the http://www.cleonis.nl/physics/phys256/angular_momentum.php"
You can see that a particle in uniform motion will sweep out equal areas in equal intervals of time, similar to Kepler's area law. Hence in the case of an object in uniform motion you can take any point in space that is in uniform motion and define the angular momentum of that object with respect to the chosen "pivot" point.
If you have two objects in uniform motion, you can define the sum of their angular momentums with respect to their common center of mass. If the two object sudden start exerting a force upon each other the angular momentum will be conserved.
On my website there is also a http://www.cleonis.nl/physics/ejs/angular_acceleration_simulation.php" . Interestingly, conservation of angular momentum can be regarded as a logical consequence of the work/energy theorem.
Cleonis
Note that what you've got there is the equation of a straight line, in POLAR coordinates.
  • · Replies 17 ·
  • · Replies 71 ·
  • · Replies 30 ·
