Visualizing Immersions vs. Submersions
  • Context: Graduate
  • Thread starter Thread starter dreamtheater
The discussion focuses on the visual and intuitive distinctions between immersions and submersions in differential geometry, specifically using the Klein Bottle as an example. The Klein Bottle is identified as an immersion in R^3, demonstrating a differential map that is one-to-one but not onto due to its self-intersection. Participants explore how to visualize a copy of the real line in R^3 as both an immersion and a submersion, emphasizing that a submersion can be represented by a map from R^2 to R^1 without critical points, allowing for visualization as a graph in R^3.
  • Understanding of differential geometry concepts such as immersions and submersions.
  • Familiarity with the Klein Bottle and its properties in R^3.
  • Knowledge of Jacobian matrices and their role in determining immersions.
  • Basic concepts of local diffeomorphisms and covering maps.
  • Study the properties of the Klein Bottle and its representation in R^3.
  • Learn about Jacobian calculations to identify immersions and submersions.
  • Explore local diffeomorphisms and their implications in differential geometry.
  • Visualize mappings from R^2 to R^1 to understand submersions without critical points.
Mathematicians, students of differential geometry, and anyone interested in the visual representation of complex geometric concepts such as immersions and submersions.
dreamtheater
What is the best way to intuitively and visually distinguish between immersion and submersions? For example, I understand that the standard picture of the Klein Bottle in R^3 is an immersion. How do I see this? (Obviously, it's not an embedding because the Klein Bottle self-intersects in R^3. But how do I see that the differential map is 1-to-1 but not onto?) What would a submersion look like?
Also, can I visualize a copy of the real line in R^3 so that, it is an immersion but not a submersion nor an embedding? Also as a submersion but not an immersion?
The only way something can be a submersion and an immersion is if it's a local diffeomorphism (e.g. a covering map, like the real line to S^1). It's difficult to tell by visual inspection if a map is an immersion - you just calculate the Jacobian. A submersion can most readily be seen by a map R^2->R^1 with no critical points (since then you can visualize it as a graph in R^3).
it is am immersion because there is a tangent plane
it is not onto because the normal does not lie on the tangent plane
a line that spirals infinitely around a point and converges to that point is not embedded.
  • · Replies 44 ·
  • · Replies 20 ·
  • · Replies 39 ·
