Which single-valued differentiable function between 0 and 1 satisfies
  • Context: Undergrad
  • Thread starter Thread starter Wiemster
    Differentiable Function
The discussion revolves around finding a single-valued, differentiable function u(x) defined on the interval [0, 1] that satisfies the conditions u(0) = 0 and u(1) = 1, while allowing for the selection of derivatives u'(0) and u'(1) through free parameters. The focus includes the requirements of monotonicity and the implications of derivative values on the function's behavior.
  • One participant proposes the function u(x) = x + A*sin(pi*x) + B*sin(2*pi*x) and derives expressions for u'(0) and u'(1) based on parameters A and B.
  • Another participant suggests a cubic polynomial form u(x) = ax^3 + bx^2 + x(1-a-b) and discusses how to set derivatives u'(0) and u'(1) to arbitrary values p and q.
  • A later reply clarifies the requirement for the function to be monotonic, stating that previous solutions do not meet this criterion.
  • Some participants argue that if u'(0) or u'(1) is negative, monotonicity cannot be maintained, leading to contradictions in the function's behavior.
  • One participant mentions the possibility of using an error function, but expresses concerns about the independence of u'(0) and u'(1) in this context.
  • Another participant suggests that constructing a function may depend on distinct cases for the values of u'(0) and u'(1), particularly when both are greater than 1.
  • There is a discussion about using a sine function to satisfy the conditions, with concerns about maintaining monotonicity.
  • One participant proposes a piecewise linear function as a potential solution, while another expresses a desire for a single elementary function without discontinuities.
  • A participant mentions matching two exponential functions to influence the shape of the function, but acknowledges this results in a piecewise definition.
Participants generally disagree on the feasibility of constructing a monotonic function under the specified conditions, particularly regarding the implications of negative derivatives. There is no consensus on a single function that meets all criteria, and multiple competing views on potential solutions are presented.
Participants express uncertainty regarding the implications of derivative values on function behavior, particularly in relation to continuity and monotonicity. The discussion also highlights the complexity of finding a suitable function that satisfies all stated requirements.
Wiemster
I look for a function u(x) with u(0)=0 and u(1)=1, which is single-valued and differentiable on the entire interval x= [0,1] and allows one to choose the derivatives u'(0) and u'(1) through two free parameters.
Seems simple enough, right?
u'(0) = 1 + pi*A + 2*pi*B
u'(1) = 1 - pi*A + 2*pi*B
A = (u'(0) - u'(1)) / (2*pi)
B = (u'(0) + u'(1) - 2) / (4*pi)
u(x) = ax^3 + bx^2 + cx + d?
u(0) = 0 --> d = 0
u(1) = 1 --> a + b + c = 1 so c = 1-a-b
so your function is:
u(x) = ax^3 + bx^2 + x(1-a-b) -----------(*)
Say you need the derivatives to arbitrarily be p and q at x = 0 and 1 respectively,
u'(x) = 3ax^2 + bx + 1 - a - b
so u'(0) = p, u'(1) = q mean that:
1 - a - b = p ---------------(1)
3a + b + 1 - a - b = q ------(2)
(1) means we can fix b = 1 - a - p, substitution into (2) means:
3a + (1 - a - p) + 1 - a - (1 - a - p) = q
3a + 1 - a - p + 1 - a - 1 + a + p = p
2a + 1 = q
So for any two gradients you need, (p,q) at the points (0,1), your parameters (a,b) in the function (x) given above (*) are ((q-1)/2, 1 - (q-1)/2 - p).
I think this works...
Thank you both very much, and both solutions indeed do the job. However I must say I made a mistake in saying that I wanted the function to be single-valued.
What I actually want is that the function is monotonic, so that it only increases from x=0 to 1. Both proposed solutions do not always satisfy this criterion, sadly enough. Can a function be devised which is monotonic?
I don't think this is possible in the case u'(1) < 0 or u'(0) < 0.
For u(x) to be continuous, the limit must equal the value, so lim(u) as x goes to zero from above must be zero. However if you specify a negative gradient at this point, it implies that within a neighbourhood around 0, u is negative for at least some range x in (0,epsilon), and if u is negative for some x in [0,epsilon), but u(1) = 0 and u(x) is continuous, then there must be a second value, say a, for which u(a) = 0 in the range (epsilon,1)- so since u(0) = u(a) it cannot be monotonic.
Been a long time since I've done real analysis so I feel this is quite a shaky proof.
You're right! So I am indeed only interested in functions with u'(0) and u'(1) between 0 and 1. I understand I change the problem all the time, apparently I didn't think it through all the way.
I was thinking that an error function erf((x-m)/s) does part of the trick, when properly shifted and rescaled. But then there is the problem of finding m and s in terms of u'(0) and u'(1), which probably cannot be done analytically. And more problematically, u'(0) and u'(1) cannot be chosen independently anymore, I guess.
So maybe there is a simpler function that can do the trick and which does allow one to easily adjust u'(0) and u'(1)?
Yes, that's only possible if both derivatives are nonnegative, for obvious reasons. Much trickier to do, too. It seems that we have to consider several distinct cases depending on values of u'(0) and u'(1). For example, when they are both greater than 1, we can construct the necessary function out of x^a and 1-(1-x)^b. Can't think of a good function that works for all values.
you can simply say that a single-valued function is monotonous=>u' keeps its sign on [0,1].
also u(1)>u(0) => u' must be positive on [0,1].
Can't a u(x) = a*sin(b*x + c) + d function satisfy this? I don't have the time to prove it, but for any positive gradients I can imagine a simple manipulation of the frequency/amplitude satisfying this...
With this choice you cannot get u'(1)>1, without losing monotonicity on [0,1] I think.
This is a tough one. In probabilistic speak, you want to construct a distribution on [0,1] with a continuous density function that is prescribed at 0 and 1.
I take it you want the mass to shift smoothly around [0,1] as the parameters vary. What about making the density a piecewise linear function, e.g. with a W shape?
u'(0)=a
u'(x1)=0
u'(1/4)=0
u'(1/2)=c
u'(3/4)=0
u'(x2)=0
u'(1)=b
x1=min(1/4,1/a)
x2=max(3/4,1/b)
choose c so that total area is 1, i.e. c = 4-2.a.x1-2.b.(1-x2)
With piecewise functions it should indeed be much more easy to escape from Runge's phenomenon, I would however be interested in finding a single (i.e. without Heaviside step functions) elementary function that is able to satisfy my demands.
Do you want a function that's infinitely differentiable?
You'll be hard pressed to find one simpler to compute.
It does not necessarily have to be infinitely differentiable. I now matched two exponential functions: u1(x) = a1*exp(b1*x)+c1 and u1(x) = a2*exp(b2*x)+c2 at x=x0. The constants a1,a2 and c1,c2 follow from u(0)=0, u(1)=1, u1(x0) = u2(x0), u2(x0)=u2(x1). The three constants b1, b2 and x0 can then be used to influence the shape. This is fine for my purposes. But thanks anyway for your suggestions.
Wiemster said:
I now matched two exponential functions at x=x0
That would still be a piecewise function wouldn't it?
Yep, I gave up...:redface:
