Concept of Elasticity on an atomic level
The discussion centers on the concept of elasticity at the atomic level, specifically how a metal rod extends under external load. When a load is applied to one end of a rod, the interatomic separation increases due to the applied force, which generates restoring forces between adjacent atoms. The behavior of atoms during this process can be modeled using the Lennard-Jones potential, illustrating the relationship between potential energy and distance. For further understanding, the book "Materials Science" by William D. Callister is recommended for insights into atomic-level elasticity.
  • Understanding of atomic structure and interatomic forces
  • Familiarity with elasticity concepts, including Hooke's Law
  • Knowledge of potential energy graphs, specifically Lennard-Jones potential
  • Basic principles of materials science
  • Study the Lennard-Jones potential and its applications in material deformation
  • Explore the relationship between stress, strain, and atomic separation in materials
  • Investigate advanced elasticity theories beyond Hooke's Law
  • Read "Materials Science" by William D. Callister for comprehensive insights into atomic-level elasticity
Materials scientists, mechanical engineers, and students studying the atomic behavior of materials under stress will benefit from this discussion.
RohansK
Hi guys,
Can someone explain The concept of ELASTICITY on an atomic level.
To be clear can somebody please try and elaborate on how does a metal rod or bar or wire start to extend under the influence of an external load.
What exactly happens on the interatomic level, say we consider ( for the purpose of ease and understanding) a single layer of atoms ( a horizontal line of atoms 0-0-0-0-0-0-0-0-0) where 0 is an atom and - inidcates the separation between two consecutive atoms) and a load applied at one end on the first atom and the last atom is fixed into a support like a wall.
Then How exactly will the atoms behave and how actually will the interatomic separation increase between two consecutive atoms, how will the interatomic restoration forces influence them and their forward movement ie increase in separation.
What will be the position of two consecutive atoms wrt each other ( for the first pair for eg.) at a particular instant of time ie the distance between them and the forces acting on them.
Say that the first atom is pulled by the applied load then as it starts to move forward due to the pull the separation between it and the second atom increases. Then how exactly the forces will be developed between it and the second atom and how will these forces increase /decrease ( wrt the PE v/s Distance graph) on each others. How will the distances, interatomic seperations and speeds of each of them keep changing wrt time say from the start to the complete deformation reached and the condition of the above parameters for each of the atoms at a few intervals of time from start to end.
Though it may not come very close to reality Can anyone give a very crude estimation to visualise this ( it may be simply an rough analogy just to try to understnad the whole thing at atomic level)
Or can you suggest some books on the ELASTICITY which handles the subject at atomic level explanations or close to it. So as to get a better picture of what's going on inside than just taking for granted the Hookes Law and deformation and the equations of elasticity.
Thanks and Regards.
Atoms in unstrained solids are spaced at a distance that corresponds to a minimum energy; when we elastically deform the material, this distance changes and energy increases, producing a restoring force. The interaction is often modeled at a simple level as a http://en.wikipedia.org/wiki/Lennard-Jones_potential" . Take a look at Callister's introductory book on materials science for more information.
  • · Replies 23 ·
  • · Replies 35 ·
  • · Replies 85 ·
10K
