| Thread Closed |
URGENT: PM Generator in Reverse |
Share Thread | Thread Tools |
| Oct23-09, 02:36 PM | #1 |
If you have a permanent magnet generator being driven by a turbine and the generator outputs some power level, how would the configuration of a generator change if it is suppose to drive a turbine's compressor stage with the same power?
I think the meaning is how would one change the generator to a motor that supplies the same output power. I just don't understand applying electrical power to the stator would make a PM rotor move. Any details would be appreciated. |
| Oct23-09, 07:17 PM | #2 |
"Generators" with permanent magnet (PM) rotors run well as dynamos but not as motors. The dynamo would require some way of commutating (reversing) the stator current depending on the rotor angle. This is done in BLDC (brushles dc) motors that either have a Hall Effect sensor, or use a stator coil induced voltage (from rotor) sensor to commutate the stator current.
Bob S |
| Thread Closed |
| Thread Tools | |
Similar Threads for: URGENT: PM Generator in Reverse
| Van De Graff Generator: Explanations to why object repel generator | Introductory Physics Homework | 1 | ||
| Generator Shaft Power (Input) to Generator Out | Mechanical Engineering | 1 | ||
| Van de Graff Generator: Electrostatics, why do objects repel the generator | Advanced Physics Homework | 0 | ||
| Flywheel Generator - Split from Propane Solar Collector/Generator Thread | Mechanical Engineering | 52 | ||
| Quantum Mechanics Homework Help(Urgent Urgent Urgent)! | Advanced Physics Homework | 3 | ||
