Standard Model Lagrange Density, 2D vectors, Lattice Theory.
The discussion revolves around the representation of various fields and degrees of freedom in the context of the Standard Model Lagrange Density and lattice theory. Participants explore the implications of using 2-dimensional arrows to represent these concepts, questioning the nature of lattice calculations and their relation to classical and quantum theories.
  • One participant questions whether lattice calculations are classical or require a quantized theory, and how many arrows are needed to represent degrees of freedom in the Standard Model.
  • There is a proposal that the color force requires three arrows, the weak force two arrows, and the electric field one arrow, leading to a total of four arrows for a non-interacting Dirac particle.
  • Another participant discusses the degrees of freedom for subatomic particles, suggesting a total of 12 degrees of freedom for a particle, but acknowledges that not all particles experience all degrees.
  • A participant challenges the accuracy of a previous post's calculations regarding degrees of freedom, suggesting a total of 220 degrees of freedom for the Standard Model Lagrange Density.
  • There is a mention of string theory potentially having more degrees of freedom than the Standard Model due to supersymmetry, with a request for an explanation on how to count these degrees of freedom in string theory.
  • One participant introduces Regge calculus as a lattice approximation of general relativity, discussing its relation to the metric and the action.
  • Another participant attempts to identify a pattern in the number of arrows needed to represent different fields, proposing specific values for general relativity, Dirac fields, color fields, weak fields, and electric fields.
Participants express differing views on the nature of degrees of freedom in particle physics, the representation of fields on a lattice, and the implications of string theory. There is no consensus on the total number of degrees of freedom or the correct interpretation of lattice calculations.
Some claims depend on specific definitions and assumptions about particles and fields, and there are unresolved mathematical steps in the discussion regarding degrees of freedom.
Spinnor
In the article "The Lattice Theory of Quark Confinement", by Claudio Rebbi (Scientific American) there is a graphic representing the chromoelectric field. The caption reads:
"Chromoelectric field is a gauge field similar in principle to the electromagnetic field but more complicated mathematically. At every point on a lattice there are three arrows instead of one; they correspond to the color charges of a quark. Moreover, the color gauge field affects not only the direction of each arrow but also its length. ..."
Are such lattice calculations considered classical or does one need to bring the full force of the quantized theory?
On a lattice can I assume we can let 2-dimensional arrows represent every "degree of freedom" of the Standard Model Lagrange Density?
If so, how many arrows at a point do we need to account for the "freedom" of both the matter fields and the force fields?
The color force seems to need three arrows, two arrows for the weak force, one arrow for the electric field, a non-interacting Dirac particle needs 4 arrows at each point in a space-time lattice for each Dirac particle?
Lots of arrows? If string theory turns out to be true how many arrows do we need to represent what's going on at a point in a space-time lattice?
Are there relationships among the various arrows which reduces their "freedom"?
If there is a lattice approximation of classical general relativity? Can we represent the physics of general relativity with some number of 2-dimensional arrows at each point in the space-time lattice? (yikes, now the space-time lattice is not fixed?)
Thanks for your thoughts.
Doing a Google search of "internal degrees of freedom" I came up with this thread which I think addressed one of my questions above. The post I think has a simple math error and I would appreciate your thoughts on the accuracy of the post. The thread is found at:
http://www.advancedphysics.org/forum/showthread.php?t=560
The question is:
"How many degrees of freedom exist?
My question is straight forward: how many degrees of freedom exist for any given sub atomic particle? I would say that 3 spatial dimensions as well as time do. Quarks exhibit 3 degrees of freedom in the form of color charge; would another degree be electromagnetic charge? Similarly, I\'ve read that spin offers another 4 degrees of freedom: particle and antiparticle states with two possibilities for handedness. That would bring the total number of degrees of freedom for a particle up to 12, though some particles don\'t experience all these degrees (Neutrinos only see two spin degrees, leptons don\'t seem to carry color charge, etc). Is this all correct? Are there perhaps any more degrees of freedom?"
The answer:
"This is almost certainly not the right way to think about the problem. In field theory, spatial coordinates are not properties of particles; rather, particles are properties of spatial coordinates. In addition, most of the degrees of freedom you specified should be considered different kinds of particle. So the real question would be, how many different kinds of particle are there?
Quarks
3 generations
3 colors
4 isospins (2 in a doublet + 2 in singlets)
2 spins
2 matter-antimatter
= 144 DoF
Leptons
3 generations
1 color
3 isospins (2 in a doublet + 1 in a singlet) <-- assumes no right-handed neutrino!
2 spins
2 matter-antimatter <-- assumes neutrino not its own antiparticle
= 108 DoF "
Math error? The number 108 should be 48?
"Vector Bosons
8 gluons + 4 W-Z-photons
2 polarizations
= 24 DoF
Higgs
2 isospins
2 complex
= 4 DoF <-- 3 become transverse polarizations of W and Z, 1 remains higgs
Total: 280 DoF?"
For a total of 220 DoF?
"If I got all these right, that is...
Xerxes"
So to answer my question, the Standard Model Lagrange Density has about 220 degrees of freedom?
So do I understand it correctly, string theory has all these degrees of freedom and more?
Does string theory nearly double the number of degrees of freedom of the standard model because of super-symmetry?
Can someone give me a hand waving explanation how in principle we would count the degrees of freedom in string theory?
Thank you for any thoughts!
There is a "lattice approximation" to GR, it's called Regge calculus. The basic variable is the square of a link length. The action is varied with respect to this quantity and it is, of course, directly related to the metric. There is a good introduction in Misner, C.W., Thorne, K.S., Wheeler, J.A.: Gravitation. W.H. Freeman, San Francisco (1973), p 1162 (or thereabouts).
The color force seems to need three arrows, two arrows for the weak force, one arrow for the electric field, a non-interacting Dirac particle needs 4 arrows at each point in a space-time lattice for each Dirac particle? ...
Is there a pattern below?
5 arrows worth of information at a point for General Relativity,
4 arrows worth of information at a point for Dirac field,
3 arrows worth of information at a point for color field,
2 arrows worth of information at a point for weak field,
1 arrows worth of information at a point for electric field?
  • · Replies 0 ·
10K
  • · Replies 26 ·
  • · Replies 75 ·
11K
