Calculating Neutrino Binding in Gravitational Potentials
The discussion revolves around the potential for gravitational binding of neutrinos within the gravitational potential of our galaxy, particularly focusing on the implications of their four-momentum and speed. Participants explore theoretical estimates and the conditions under which neutrinos might be trapped in the galaxy's gravitational well.
  • Some participants suggest that knowing the four-momentum of a neutrino could allow for calculations regarding its potential binding within the galaxy's gravitational field.
  • One participant provides an order of magnitude estimate relating energy, temperature, and gravitational effects, noting a difference in clumping behavior between neutrinos and photons.
  • Another participant discusses the escape velocity required for an object to leave the galaxy, suggesting that some neutrinos may travel slower than this threshold and could be bound within the galaxy.
  • There is speculation about the mechanisms that could slow down neutrinos to the necessary speeds for gravitational binding, including the effects of cosmic expansion.
  • A participant notes that the mass of cold neutrinos is insufficient to account for a significant portion of cold dark matter, indicating the need for other particles.
Participants express multiple competing views regarding the conditions under which neutrinos might be gravitationally bound, and the discussion remains unresolved with no consensus reached on the specifics of the binding conditions or the implications of neutrino speeds.
There are limitations regarding the estimates of gravitational binding, including uncertainties in the total mass of the galaxy and the distribution of neutrino speeds. The discussion also highlights the dependence on various assumptions about neutrino behavior and cosmic conditions.
Spinnor
If we knew the four momentum of a neutrino should we then be in position to calculate whether the gravitational potential of our galaxy might "bind" that neutrino?
Thank you for any thoughts.
Space news on Phys.org
Yes.
It is not hard to get an order of magnitude estimate: [itex]E \approx kT \approx GM/r \approx G \rho r^2[/itex], or [itex]r \approx \sqrt{kT/G \rho}[/itex].
Now, the temperature of the neutrinos is about 2K instead of 2.7K for photons- I dimly remember a cub root of 4/11 in the problem, but that's not important - so there's only about a 15% difference in the radius at which neutrinos clump vs. where photons clump. Since we don't see significant photon "clumping" - CMBR anisotropies are small - we don't expect significant neutrino clumping on cosmological scales either.
Spinnor,
Check out the Wikipedia article on escape velocity.
http://en.wikipedia.org/wiki/Escape_velocity
It says that for an object to escape the galaxy (starting from as far out from galaxy center as we are) it has to have a speed of roughly 1000 km/second.
Neutrinos come with all different speeds. Some are relativistic, but that wouldn't necessarily be true for all of them. There could well be some neutrinos around here which are traveling less than 1000 km/second and which are bound----trapped in the potential well of the galaxy.
That speed is atypically slow for a neutrino. One typically thinks of them traveling near the speed of light, which is 300,000 km/second.
The reason I'm answering your question this way is because you asked if we knew the momentum of a particular neutrino, what could we say? Another way to put the question is to ask how slow would one have to be going, in order to be trapped?
The figure of 1000 is only ballpark---because there is a cloud of dark matter around our galaxy we don't have a precise estimate of its total mass. The mass further in is easier to estimate. The sun is orbiting the center of galaxy at a speed of about 250 km/second. We can measure that and calculate the total amount of mass inside the sun's roughly circular orbit, but much further out we don't have such a good handle.
Given that it is only a rough estimate one can still say that in order to be trapped a particle (like a neutrino) would need to be slowed down to about 1/300 of the speed of light.
Slowed down from around 300,000 to around 1000 km/second. And we could ask, what could have slowed a neutrino down that much? Is there any mechanism? For example could the expansion of the universe have "cooled" some neutrinos so much that some are traveling only 1/300 of the speed of light?*
Is that where your question seems to point? If you want to pursue that line of questioning then there are more things to ask about.
Vanadium already gave you an answer in terms of the statistical or thermal distribution of speeds. Along those lines you might be able to find out what fraction of the background of early universe neutrinos are by now going less than 1/300 c.
Interesting thought.
(BTW it is said that there is not enough mass in cold neutrinos to account for a significant part of the cold dark matter, so there has to be some other kind of particle. It would still be interesting to try to follow the reasoning.)
*EDIT: Nobody answered, so I'll give it away :biggrin: Yes the expansion does slow neutrinos down.
  • · Replies 21 ·
  • · Replies 26 ·
