Karno Maps for Seven Segment Display Circuits - CAPSULE Spelling Exercise
  • Context: Engineering
  • Thread starter Thread starter fallen186
    Circuits
The discussion focuses on creating a Karnaugh map for a seven-segment display circuit to spell the word "CAPSULE" using three inputs (A, B, C) and seven outputs (a, b, c, d, e, f, g). The provided Karnaugh maps yield simplified Boolean expressions for each segment, with specific errors identified in the user's expressions. The correct expressions include A' + B for segment 'a' and A'C + BC + A(BC)' for segment 'c'. The user seeks assistance in constructing the circuit and clarifying the use of reflected Gray code for binary inputs.
  • Understanding of Karnaugh maps and Boolean algebra
  • Familiarity with seven-segment display circuits
  • Knowledge of digital logic design principles
  • Experience with circuit construction and simplification techniques
  • Study the construction of Karnaugh maps for three-variable systems
  • Learn about reflected Gray code and its application in digital circuits
  • Research circuit design techniques for seven-segment displays
  • Explore Boolean algebra simplification methods for digital logic
Electronics students, digital circuit designers, and hobbyists interested in implementing and troubleshooting seven-segment display circuits using Karnaugh maps.
fallen186
Three input and seven output. Do the karno map.
This is suppose to be a seven segment display ( like the ones in digital clocks.) I am suppose to spell a word. My word was CAPSULE. I got an error and I can't trace it.
CAPSULE:
A B C | a | b | c | d | e | f | g |
0 0 0 | 1 | 0 | 0 | 1 | 1 | 1 | 0 |
0 0 1 | 1 | 1 | 1 | 0 | 1 | 1 | 1 |
0 1 0 | 1 | 1 | 0 | 0 | 1 | 1 | 1 |
0 1 1 | 1 | 0 | 1 | 1 | 0 | 1 | 1 |
1 0 0 | 0 | 1 | 1 | 1 | 1 | 1 | 0 |
1 0 1 | 0 | 0 | 0 | 1 | 1 | 1 | 0 |
1 1 0 | 1 | 0 | 0 | 1 | 1 | 1 | 1 |
1 1 1 | x | x | x | x | x | x | x |
Karno map
a
1 | 1 | 1 | 0
1 | 1 | x | 0
= A' + B
b
0 | 1 | 0 | 1
1 | 0 | x | 0
= (AB)'C + A'BC'+ A(BC)'
c
0 | 0 | 0 | 1
1 | 1 | x | 0
= A'C + BC + A(BC)'
d
1 | 0 | 1 | 1
0 | 1 | x | 1
=A + BC + (BC)'
e
1 | 1 | 1 | 1
1 | 0 | x | 1
= C' + B'
f
1 | 1 | 1 | 1
1 | 1 | x | 1
F = 1
** By the way how do I make a circuit of this. I orginally did A' + A
g
0 | 1 | 1 | 0
1 | 1 | x | 0
= B + A'C
Any help will make me greatful
Is the word CAPSULE to be spelled out as the binary inputs cycle in order from 0 through 6?
I haven't done Karnaugh maps for an age but as I recall, don't you want to list the binaries under ABC as a reflected gray code? And the answer to f is just connect that input to vc.
Also, for example in your expression for b, where you write expressions like (AB)'C, where apparently you mean A'B'C, those expressions aren't equal and your expression isn't correct.
  • · Replies 26 ·
  • · Replies 21 ·
