Calculating Vertical Jump Kinetics
This discussion focuses on calculating vertical jump kinetics using force plate data. Key calculations include the work done during the jump, potential energy gain at the peak height, and the impulse exerted on the force plate. The work can be determined using the formula W=Fd, where F is force and d is displacement. Potential energy is calculated using the standard formula E=mgh, and impulse is defined as the change in momentum.
  • Understanding of Newton's laws of motion
  • Familiarity with the concepts of work and energy
  • Knowledge of impulse and momentum equations
  • Basic proficiency in data analysis and interpretation
  • Research the formula for calculating work done in physics
  • Study the potential energy formula E=mgh in detail
  • Explore the relationship between impulse and momentum
  • Learn how to analyze force plate data for biomechanics applications
This discussion is beneficial for biomechanics researchers, sports scientists, and physical therapists interested in analyzing vertical jump performance and understanding the underlying physics of human movement.
Jim Newt
I'm working on a problem that analyzes vertical jump kinetics. I have a data file that has force plate data and corresponding time steps when a person jumped straight up and then landed on a force plate. I also have the vertical distance that the person jumped.
I want to calculate:
1. The work done to move the body (in the jump)
2. The potential energy gain at the highest point in the jump
3. The impulse created on the force plate
Does anyone have any suggestions as to how I go about doing this?
Thanks,
Jim
If this is homework or an assignment, then I can't give you answers directly, you'll have to work a little harder for that, but here are some hints:
1. In a vertical jump, what is the total displacement if the jumper leaves and returns to the same position, remember that W=Fd, Work is force mulitplied by displacement.
2. what is the standard form used for potential energy? Kinetic energy, for example, is E=1/2mv²
3. Impulse is also known as the change of momentum, what do the momentum equation and the impulse equation look like?
  • · Replies 19 ·
  • · Replies 33 ·
  • · Replies 23 ·
