Register to reply
Point on surface closest to origin.
by mathman44
Tags: closest, origin, point, surface
Share this thread:
mathman44
#1
Oct25-09, 07:11 PM
P: 210
Hello all. The question asked here is to find the point on the surface:
z2 - xy = 1
that is closest to the origin.
3. The attempt at a solution
I only have experience in doing this with 2 variables. I begin by trying to find "d", I get that d = sqrt[...] but I have three variables to deal with. I end up with
d2 = (z2-1)/y + (z2-1)/x + xy + 1
The problem is that the partial derivatives with respect to x, y and z are quite messy and they don't look right... Does this look correct so far? Thanks all!
Phys.Org News Partner Science news on Phys.org
Hoverbike drone project for air transport takes off
Earlier Stone Age artifacts found in Northern Cape of South Africa
Study reveals new characteristics of complex oxide surfaces
Mark44
#2
Oct25-09, 08:13 PM
Mentor
P: 21,216
You want the points on this surface whose distance is smallest. This means you want to minimize
[tex]d~=~\sqrt{x^2 + y^2 + z^2}~=~\sqrt{x^2 + y^2 + xy + 1} [/tex]
In the second square root, I replaced z2 with an expression it is equal to, because of the definition of the surface.
Equivalently, you can minimize the distance squared, which is
d2 = f(x, y) = x2 + y2 + xy + 1
You need to keep in mind that there is a domain here, {(x, y) | xy + 1 >= 0}. It seems very likely to me that you'll have a minimum point on the boundary of this domain.
mathman44
#3
Oct25-09, 09:34 PM
P: 210
Tyvm.
HallsofIvy
#4
Oct26-09, 05:12 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,316
Or you could use Lagrange multipliers. Since the same point that minimizes distance will minimize distance square you can take [itex]F(x,y,z)= x^2+ y^2+ z^2[/itex] as the function to be minimized subject to the constraint that [itex]G(x,y,z)= z^2- xy= 1[/itex].
The max or min will occur where [itex]\nabla F[/itex] and [itex]\nabla G[/itex] are parallel- that is, that [itex]\nabla F= \lambda\nabla G[/itex] for some number [itex]\lambda[/itex], the "Lagrange multiplier".
Here that becomes [itex]2x\vec{i}+ 2y\vec{j}+ 2z\vec{k}= \lambda(-y\vec{i}- x\vec{j}+ 2z\vec{k})[/itex]
lanedance
#5
Oct26-09, 05:49 AM
HW Helper
P: 3,307
thats interesting geomtrically as well, as [itex]\nabla G[/itex] is perpindicular to the level surfaces of G(x,y,z).
And [itex]\nabla F[/itex] will always point in the radial direction of the position vector
so i think you could probably use this to show that the vector connecting a point with the closest point on a given surface, will be normal to the tangent plane of the surface...
Register to reply
Related Discussions
X value closest to origin - phases difference - answer does not match teachers Introductory Physics Homework 1
Orthogonality, point on line closest to point in space Calculus & Beyond Homework 3
Find the closest point to the origin on the curve of intersection to a cone Calculus & Beyond Homework 4
Calc Optimization - Point on an ellipse closest to origin. Calculus & Beyond Homework 6
The closest point in the plane Linear & Abstract Algebra 1
