Register to reply
Moment of inertia of a disk by integration
by soopo
Tags: calculus, disk, moment of inertia
Share this thread:
soopo
#1
Oct27-09, 05:07 PM
P: 226
Show that the moment of inertia of a disk is [itex] 0.5 mr^2 [/itex].
3. The attempt at a solution
[tex] I = \int R^2 dm [/tex]
Using [itex] dm = \lambda dr [/itex] such that [itex] m = \lambda r [/itex]:
[tex] = \int_{-r}^{r} R^2 \lambda dr [/tex]
[tex] = \frac { \lambda } {3} ( 2r^3 ) [/tex]
[tex] = \frac {2} {3} (\lambda r ) (r^2) [/tex]
[tex] = \frac {2} {3} M R^2 [/tex]
which should be the moment of inertia for a ring.
Integrating this from 0 to 2pii relative to the angle gives me [itex] \frac {4} {9} m r^3 [/tex],
which is wrong.
How can you calculate the moment of inertia for a disk?
Phys.Org News Partner Science news on Phys.org
NASA team lays plans to observe new worlds
IHEP in China has ambitions for Higgs factory
Spinach could lead to alternative energy more powerful than Popeye
jdwood983
#2
Oct27-09, 05:33 PM
P: 383
Quote Quote by soopo View Post
which is wrong.
If you have a disc of radius [tex]r[/tex], how can you integrate from [tex]-r[/tex] to [tex]r[/tex]?
jdwood983
#3
Oct27-09, 05:36 PM
P: 383
The infinitesimal change in mass is given by
[tex]
dm=m\frac{dA}{A}=m\frac{2\pi r\,dr}{\pi R^2}=\frac{2m}{R^2}r\,dr
[/tex]
If you use that in your integral and integrate from [tex]0[/tex] to [tex]R[/tex], you should get the desired result.
soopo
#4
Oct27-09, 05:53 PM
P: 226
Quote Quote by jdwood983 View Post
[tex]
[/tex]
Your result gives me a wrong result:
[tex] = \int R^2 \frac { 2m } {R^2} r dr [/tex]
[tex] = \int_{0}^{r} 2mr dr [/tex]
[tex] = [ m r^2 ]^{r}_{0} [/tex]
[tex] = mr^2 [/tex]
The result shoud be [tex] I = .5 mr^2 [/tex]
soopo
#5
Oct27-09, 05:55 PM
P: 226
I set the null point to the center of the circle such that I am integrating from -r to r.
I am not sure why I cannot do that.
jdwood983
#6
Oct27-09, 06:04 PM
P: 383
If you set the origin to the center of the circle (which you should always try to do), the smallest value that [tex]r[/tex] can be is 0. So it is physically impossible to integrate from [tex]-r[/tex] to [tex]r[/tex], that is why you can't do it.
soopo
#7
Oct27-09, 06:17 PM
P: 226
I am thinking of setting an axis which goes through the origin such that the zero point of the axis is at the origin. Going to right means to go towards [tex]r[/tex], while going to left means towards [tex]-r[/tex].
Perhaps, you are thinking the situation in a polar coordinate system in which case you cannot have negative [tex]-r[/tex].
I feel that it is possible to integrate from [tex]-r[/tex] to [tex]r[/tex] in a cartesian coordinate system.
jdwood983
#8
Oct27-09, 07:26 PM
P: 383
If you want Cartesian coordinates, then you'll need two integrals: one over [tex]x[/tex] and one over [tex]y[/tex]. While technically you have two integrals in polar, [tex]r\, \mathrm{and}\, \theta[/tex], one is already done for you and reduces the integration to just one term: [tex]r[/tex].
This problem is by far easier in polar coordinates:
[tex]
\begin{array}{ll}I&=\int_0^R r^2\frac{2m}{R^2}rdr
\\ &=\frac{2m}{R^2}\int_0^Rr^3dr
\\ &=\frac{2m}{R^2}\left(\frac{R^4}{4}-0\right)
\\ &=\frac{2m}{R^2}\cdpt\frac{R^4}{4}
\\ &=\frac{1}{2}mR^2
[/tex]
soopo
#9
Oct27-09, 10:50 PM
P: 226
If you use symmetry, it is enough to consider only the first quadrant that is where x > 0 and y > 0 such that four of these quadrants form the area of the disk.
You do not get the x- and y -coordinates easily from the definition of the moment of inertia.
You would get
[tex] I = \int (x^2 + y^2) dm
\\ &= \int (x^2 + y^2) m \frac { 2r } {R^2} dr
[/tex]
The calculations seem to get challenging, since we need to use Pythogoras such that
[tex] r = \sqrt{ x^2 + y^2 } [/tex]
which implies
[tex] dr = \frac { 1 } { \sqrt {x^2 + y^2} } * 2x [/tex]
We can get similarly the relation relative to [tex]y[/tex].
The next step is not fun at all:
[tex] I = \int_{0}^{1} \sqrt {x^2 +y^2} (x+y) x dx [/tex],
where I assume that [itex] R^2 = (x + y)^2 = (1 + 1)^2 = 4 [/itex], since it is the maximum radius.
This way the two 2s cancel out.
I do not even know how to integrate this!
Polar coordinate system really seems to be better in this case.
jdwood983
#10
Oct28-09, 07:12 AM
P: 383
Not quite. The integral you need is given by
[tex]
I=\frac{m}{A}\int_{-R}^R\int_{-\sqrt{R^2-x^2}}^{\sqrt{R^2-x^2}}\left(x^2+y^2\right)dydx
[/tex]
[tex]
I=\frac{m}{\pi R^2}\int_{-R}^R \frac{2\sqrt{R^2-x^2}\left(R^2+2x^2\right)}{3}dx
[/tex]
[tex]
I=\frac{m}{\pi R^2}\cdot\frac{\pi R^4}{2}
[/tex]
[tex]
I=\frac{mR^2}{2}
[/tex]
For most moment of inertia problems, spherical or cylindrical coordinates are the best.
soopo
#11
Oct28-09, 05:01 PM
P: 226
[tex]
[/tex]
[tex]
= \frac{\pi R^4}{2}
[/tex]
How did you solve this part?
It has taken my some effort in trying to solve it by hand.
jdwood983
#12
Oct28-09, 05:13 PM
P: 383
There's a few extra steps between the two lines, like making a change of variables. But to be honest I used Mathematica and just wrote the lines because I forget what changes needed to be made. While it may be good to know the form of the equation, I'm not sure you would need the solution since it is far easier to do it in polar coordinates than in Cartesian coordinates.
Register to reply
Related Discussions
Moment of Inertia of a Disk rotating around a rod Introductory Physics Homework 7
Moment of Inertia of the disk Introductory Physics Homework 1
Moment of Inertia of Disk at any point Classical Physics 2
Moment of Inertia and Disk Introductory Physics Homework 2
Moment of Inertia of a Disk Introductory Physics Homework 2
