Particle in a potential Well interacts with the wall without touching it?
The discussion revolves around the behavior of a particle in an infinite potential well, particularly focusing on the implications of changing the confinement volume on the particle's energy without direct interaction. Participants explore concepts from quantum mechanics, including energy levels, wavefunctions, and the nature of interactions at the quantum level.
  • One participant questions how a particle's energy can increase when the volume of confinement is decreased without any direct interaction with the particle.
  • Another participant suggests that this phenomenon is a mystery of quantum mechanics, while others argue that it is not a fallacy but rather a result of the mass interacting with the walls.
  • Concerns are raised about the practical measurability of energy differences in large mass scenarios, with one participant noting that significant energy shifts would require confinement at scales that are physically impossible.
  • Some participants discuss the implications of relativistic effects and the adiabatic theorem, highlighting that the particle's state depends on how the volume is changed.
  • There is a debate about the nature of "touching" at the quantum level and whether the wall can be said to send signals to the particle, with differing views on the interpretation of wavefunctions and system interactions.
  • One participant emphasizes that cooling the system to very low temperatures is necessary to achieve a true ground state, while another questions the feasibility of such conditions in practice.
  • The relationship between the wavefunction behavior near the walls and the kinetic energy of the particle is discussed, with one participant explaining that moving the wall affects the wavefunction's normalization and consequently the particle's energy.
Participants express a range of views, with no consensus reached on the implications of changing the confinement volume or the nature of interactions at the quantum level. Disagreements persist regarding the interpretation of quantum mechanics and the practicality of achieving certain conditions.
Participants note that the energy differences discussed may be negligible in practical terms, and the discussion includes assumptions about the ability to measure extremely small energy changes. The implications of relativistic effects and the adiabatic theorem are also highlighted as relevant to the discussion.
I_am_learning
The ground state Energy for a particle in an infinite potential well is given by
E = h2 / 8mL2
Consider a particle with high mass, say 1 kg. Then the ground state Energy will be very very low. So the velocity of the particle is very very low. It takes thousands of years for such particle to hit the walls of a say, 1m3 box that confined it.
Suppose I was able to actually setup such condition and put the particle to its lowest Energy level.
Now, If I ask a Quantum Mechanical student, What is the Energy of this particle?
He will calculate E = h2 / 8mL2 and tell me some value x.
Now, without doing anything to the particle, I decrease the volume (hence L) of confinement by say 10%.
Now, If I ask the same student about the Energy, he will use the same formula but give me another answer, say y. But y > x.
Now I ask him, Why are you supposed to say that the Particles Energy has increased, For I have never touched it, even the slightly?
What will he say now?
It's a mystery of the quantum mechanics!
If so, can't we say that its fallacy of QM.
There is no fallacy. The mass always interacts with the walls (it is not localized). When you decrease the volume, you perform work.
What is "touching" at the quantum level anyway? Why is this even mysterious?
With your numbers L=1 m, m= 1 kg, the energy difference is on the orders of h^2 ~ 1e-68 J ! ...which is zero, even exactly. Your student will say to you that he really can't measure any difference. To get a sensible shift in energy you have to confine a 1 kg ball into a nanometer cube or so, which is physically impossible, considering sizes and weights of atoms, unless you want to put a tiny black hole into the box!
Count Iblis's argument also is very convincing, I can't even feel "a mystery" here.
First thing is that I am not discussing here about whether the Energy Differences of the order 1e-68 J is practically measurable or not. Its measurable, at least theoretically, or say mathematically .
Now the mystery is the result of the thought experiment I already mentioned.
Suppose that we have got an instrument that's able to detect Energies as low as--1e-68 J.
So, my question is as soon as I decrease the volume of confinement, do the Energy Reading of the Instrument Increase? If Yes, then I was able to increase the Energy of a Distant Particle, instantly (thus sending Information faster than light??)
You're working with non-relativistic QM, so the speed of information is taken to be infinity anyway.
If you take into account relativistic effects (i.e. a finite speed of light) you will have to deal with the fact that the response of the wavefunction to your change is not instantanious. There is a retardation.
Also: The particle will only remain in the ground state with certainty if you change the volume infinitely slowly. This is the Adiabatic Theorem of quantum mechanics.
In the opposite limit you change the volume infinitely fast and then the wavefunction of the particle stays the same . In this case this so-called "sudden approximation" does not work if you decrease the volume, only if you increase the volume.
So, if you increase the volume fast enough, the wavefunction andthus the expectation value of the energy will stay the same. The particle will thus not be in the new ground state.
The effect of time varying potential can be handled even in non-relativisti QM (for "v<<c"). If you suddently start changing the potential the particle will undero a Landau-Zener transition to a new state; the probability of this transition scales with the rate of change.
Whatever be the case, (relativistic / non-relativistic),
Does QM implies that--,
if I put a small marble in a big box near the center at almost rest, the marble is always interacting with the wall, though the wall may be kilometers away, So that, any changes in the potential energy or distance between wall results in the change of marble's wave function.
If so the wall should be constantly sending Signal to the marble. What type of signal is it.
I mean, it can't surely be EM signal?
The crucial point is this:
In practice this means that that the whole system has to be cooled to a very low temperature (Exercise: estimate this temperature). Only then will the system be in the ground state and become "de-localized".
Are you trying to tell me that we can't setup such condition practically or are you trying to tell that there is no way to do that even in theoretical basis.
I don't think it is correct to think of it as "the marble's wave function". The wave function describes the state of the system, and the system includes both the marble and the box. As you change the box you are changing the system so of course the state and therefore the wavefunction must also change. In relativistic QM it does so in a way that respects relativity.
Hi.
Pressure ∂E/∂L works on the wall. You cannot but change energy by moving the wall.
Regards.
No, what I'm saying is that in the given problem, you cannot picture the marble as being in the middle of the box. If you just put the marble in the middle of the box, it will definitely not be in the ground state.
You can write down a wavefunction for the marble's center of mass motion that does describe what will go on in reality if you just put it in the middle of the box. Then you can show that changing the volume does not have any effects.
Let us consider a light QM particle in an infinitely high well of some finite size L. The wave function is zero at the well walls. Does it mean the particle does not touch the walls?
The wavefunction goes to zero near the walls. This means the derivative, and also the second derivative of the wavefunction is not zero. The kinetic energy of the wavefunction is determined through the momentum operator squared, which is precisely the second derivative of the wavefunction: [itex]\nabla^2/2m[/itex]. So the fact that the wavefunction tends to zero gives the particle some momentum and kinetic energy.
If you move the wall, you force the wavefunction to go faster to zero. This is a consequence of the fact that wavefunction stays normalized. The second derivative increases, and so does the kinetic energy.
What a use of the kinetic energy if the particle does not touch the walls?
If you're going to say that the wavefunction or particle doesn't touch the walls, then the only way to realize this is by making the wall an infinitely large and infinitely steep barrier. The typical textbook problem. It's not a very realistic model, but fine, let's just move on from here. In this case there is no overlap with the barrier since the wavefunction cannot have some value in the regime of infinite potential, so indeed, there is no "interaction energy" present.
That doesn't mean the barrier doesn't do anything. On the contrary, the barrier imposes very strict boundary conditions on the wavefunction since it needs to go to zero at the boundary, it needs to stay normalized and it needs to stay continious. In effect, the kinetic energy term goes up.
I am joking. The stationary wave function is zero because it is a superposition of two running waves - the incident and reflected. Of course, the walls participate and experience some pressure.
The more simple I wan't this thread to be the more complicated it goes.
Now, My only question is this real life scenario
I make a cardboard box of say 100000000m3. volume. I then roughly place a small marble near the center at roughly stationary with respect to cardboard (Of course you may start saying, that there is nothing like placing near center and roughly stationary, in QM, its just wave function of the particle spread out in space-time. But I am telling these scenario with respect to what I perceive, what I see). To discard complications (if any) I suppose doing this in far outer space.
Now my question is--
If I now move the walls does it change the particles behavior?
Count Iblis answered your question correctly. There is pressure on the walls, and you do work in pushing them in.
Furthermore, when you say "I have a particle in the ground state" and "I have a particle in the middle of the box", you are making two simultaneous statements- you are claiming the particle is simultaneously in an energy eigenstate and it's in a position eigenstate. This is not possible in QM. Asking that it behave classically ("But I am telling these scenario with respect to what I perceive, what I see") will surely not help you understand QM.
I have a question relating to the waves.
The stationary wave function is wave train of fineite length which is zero outside.
We can represent this wave as superposition of waves of infinite legth by Fourier transformation.
As wave images of this system, which is more appropriate?
Regards.
Do you know of some experiments to detect the pressure on the walls?
I made a big mistake there by using the word middle. I meant to say, I am sure about the particle being in ground state, but not very sure of its position.
Vanadium 50 said:
"But I am telling these scenario with respect to what I perceive, what I see" will surely not help you understand QM.
It may not, but your help will certainly help me :smile:
Is perception BANNED in QM?
In the scenario I mentioned, What do we see then? Do we see the marbles's wave function instead of seeing the marble? Do we see the marble to be spread out in the 100000m3 box, instead of seeing it somewhere?
The stationary wave function is wave train of finite length which is zero outside.
We can represent this wave as superposition of waves of infinite length by Fourier transformation. As wave images of this system, which is more appropriate?
You mean, more practical? It is the first one because it contains only one term. A Fourier series is difficult to sum up exactly and to use in some numerical calculations (iterations) due to numerical instability.
The best basis for any wave in a well is the well proper basis. It may converge quickly.
thecritic,
people have already correctly answered your question, but I think you didn't realize it - which is normal when you just started studying quantum mechanics, BTW. It is extremely counter-intuitive in the beginning.
When you say that you put your particle *in the ground state*, that means that you put it in a state where the wavefunction is non-zero everywhere in the potential well, except at the walls. That, in turn, means that the particle is "everywhere at the same time". (you can discuss about that, I prefer to say it that way, probably because my preferred mental picture is Many Worlds - it is my preferred picture exactly because it helps me explain things that way - interpretation doesn't matter for physics, but it can help to get a mental picture, an explanation). You cannot say that you "put the particle in the middle of the box" and at the same time that you "put it in the ground state". These states correspond to two different quantum states.
Now, accepting that the particle is everywhere at the same time in its ground state, if you move the walls over a finite distance, OF COURSE you have to interact with the particle, because you have to "push" it such that it isn't any more in those places where it was before the wall moved, but which are now outside the well after moving the walls.
So you had to push the particle. It is this pushing which gives it some extra energy. You will also have done work on the walls to push them - which corresponds to the pressure on the wall exerted by the particle in the ground state.
The difficulty is that you are probably still thinking of the particle to be at one place at the same time. In quantum theory, you can't see it that way.
From the moment you SEE the marble, it isn't in its ground state anymore. The act of "seeing it" has changed its state.
Thank you for your reply. I agree that the former is easier to calculate.
The benefit of the latter is to see momentum of the system, because the sinusoidal wave of iinfinite lemgth is eigenfunction of momentum. Am I right?
Regards.
sweet springs said:
...The benefit of the latter is to see momentum of the system, because the sinusoidal wave of iinfinite lemgth is eigenfunction of momentum. Am I right?
Yes, you are rigth as long as you apply it within the well premises. In fact, it is not really necessary to write the running wave outside the well:
sin(π*x/L) = [exp(iπx/L) - exp(-iπx/L)]/2i
Each exponential is already a proper function of the particle momentum. From here you see why the particle momentum is not certain: we have a superposition of different momentum eigenfunctions. Their physical sense is clear: they are running waves (incident and reflected) corresponding to a certain quantized (kinetic in this simple case) energy in the well. You see, everything is already here, no additional Fourier expansion is actually necessary.
Thanks for your quick reply. I think these two would be proper functions if they continue outside the well, but really they vanish outside. Momentum distribution is continuous not two plus-minus values. The ground state momentum wave function has only one peak at p=0.
applet in www.falstad.com/qm1d was helpful.
Regards.
