| Thread Closed |
Tapered cantilever |
Share Thread | Thread Tools |
| Oct27-09, 06:54 PM | #1 |
Tapered cantilever
Hi All,
I am analyzing a cantilevere beam which is tapered only at the lower edge. (Please see attached image) Please look at the image. I have following questions: 1. Isn't the neutral axis of a beam will be midline of upper and lower edges of beam which makes the applied vertical load to be inclined wrt neutral axis. 2. if neutral axis is inclined,do i need to resolve the applied vertical load ,normal and parallel to neutral axis? and only vertical component of load be considered (for me) to apply the classical beam bending theory. (is it anywhere mentioned in classical beam theory that vertical load be perpendicular to neutral axis) i derived vertical deflection expression from deflection equation, for above case by considering the variable sectional inertia of beam but then i think that doesn't take in inclined NA of the beam. basically i intend to find the vertical deflection of this beam and this is all what i think is going here. Any more suggestion to solve the above problem? |
| Thread Closed |
| Tags |
| beam, bending, cantilever, tapered |
| Thread Tools | |
Similar Threads for: Tapered cantilever
| Magnetism on tapered surface... | Classical Physics | 1 | ||
| Tapered Roller Bearings??? | Mechanical Engineering | 0 | ||
| Design of Tapered Sections | General Engineering | 3 | ||
| Trb (tapered Roller Bearing ) | Engineering, Comp Sci, & Technology Homework | 1 | ||
