Temperature during black hole collapse
The discussion revolves around the temperature experienced by an observer on the surface of a massive object collapsing to form a black hole. Participants explore the implications of redshift and blueshift on the effective temperature of the surface as the object approaches its Schwarzschild radius, examining concepts of thermal equilibrium and the behavior of light in strong gravitational fields.
  • One participant suggests that as the object's surface approaches its Schwarzschild radius, the blueshift from distant sources raises the effective temperature of the surface to infinity, questioning the validity of this assumption.
  • Another participant counters that the blueshift is not infinite and highlights that gravitational effects can lead to redshift, particularly for an observer falling into the black hole.
  • A clarification is made regarding the reference frame of the observer, noting that the blueshift remains finite as long as the observer does not experience unbounded 4-acceleration during the collapse.
  • Participants discuss the implications of the observer's motion, with one questioning whether a surface-bound observer would reach the event horizon in finite proper time, to which others affirm this possibility under certain conditions.
  • There is a discussion about the gravitational redshift formula and its applicability to light moving inward versus outward, with one participant expressing uncertainty about the effects on blueshift.
  • Another participant explains that the gravitational blueshift and Doppler effects must be considered together, leading to a complex interplay of shifts that could result in various outcomes, including finite or infinite shifts.
  • One participant concludes that only a "hovering" observer would see infinite blueshift, suggesting that a surface-bound observer cannot maintain such a state during collapse.
Participants express differing views on the nature of blueshift and redshift in the context of a collapsing object, with no consensus reached on the implications for effective temperature or the behavior of light near the event horizon.
Participants note limitations in their assumptions regarding the behavior of light in strong gravitational fields and the conditions under which observers experience redshift and blueshift. The discussion includes unresolved mathematical steps and varying interpretations of gravitational effects.
nickyrtr
Let's say you are an observer on the surface of a massive object that is collapsing to form an eventual black hole. As the object's surface approaches its own Schwarzschild radius, light from the object is increasingly redshifted, as seen by distant observers, approaching infinite redshift as the event horizon forms.
Correspondingly, you on the object surface see that light from distant sources is blueshifted. Now let us assume that the top layer of the object surface remains in thermal equilibrium with the incident radiation, consisting of the cosmic microwave background plus light from other stars and galaxies. As the object shrinks closer to its Schwarzschild radius, the blueshift raises the effective temperature of the cosmic background (and other sources), so it would seem that the object's surface temperature becomes infinite!
Surely this infinite temperature is unphysical, so what is the mistake in this picture I have described? Is the assumption of thermal equilibrium false? Do I misunderstand what blueshift means or how it works? Any explanation is appreciated.
The blueshift isn't infinite, and, where blueshift might be expected, there can even be a redshift.
Consider an observer that freely falls along a radial worldline feet-first into a black hole. The stars directly above the observer are redshifted for the observer. Roughly, for these stars, Doppler redshift dominates gravitational blueshift.
Also, as you note, the time taken for stellar collapse might be too short to reach (either way) thermal equilibrium.
Consider an observer that freely falls along a radial worldline feet-first into a black hole. The stars directly above the observer are redshifted for the observer. Roughly, for these stars, Doppler redshift dominates gravitational blueshift...
Well I was picturing an observer who is not falling freely, but who is supported by the surface of the collapsing object. This is the (non-inertial) reference frame of the matter that makes up the surface of the object itself.
For this surface-bound observer is the blueshift still always finite?
Yes, as long the surface observer doesn't experience unbounded 4-acceleration (infinite g-force) during the collapse.
Interesting. Will this surface-bound observer also reach the event horizon in finite proper time?
nickyrtr said:
Interesting.
I wrote this without doing a calculation, and without looking at any references, i.e., I used
Wheeler's First Moral Principal: Never make a calculation until you know the answer. ... Courage: no one needs to know what the guess is. Therefore make it quickly, by instinct. A right guess reinforces this instinct. A wrong guess brings the refreshment of surprise.
I'll take a closer look.
Yes. (Without using Wheeler's First Moral Principal)
I'm sure you're right with the acceleration. You don't need maths, just the comparison with the local free falling frame, like Rindler-Minkowski.
Perhaps my mistaken assumption was that light moving toward the collapsing star and light moving away from the star are affected equally by gravity. For example I found this formula on Wikipedia for the gravitational redshift of light emitted outward by the star:
[tex]z = \frac{1}{\sqrt{1-\frac{r_s}{r}}}-1[/tex]
Of course this diverges as the star's radius approaches rs, but perhaps this formula does not apply to light propagating inward, toward the star. Is there a different formula for the blueshift of inward-propagating light?
No, but this expression is valid only for an observer who has a fixed [itex]r[/itex] value in Schwarzschild coordinates; I call this type of observer a hovering observer.
Consider another "falling in" observer B in the neighbourhood of a hovering observer A, but with very slightly smaller [itex]r[/itex] than A. What wavelength shift for distant stars does B see? Due to relative motion between A and B, there is a Doppler redshift between A and B, so B sees the gravitational blueshift between the stars and A combined with the Doppler redshift between A and B.
Now, let A and B both approach the event horizon. A has unbounded 4-acceleration, and, if B has bounded 4-acceleration, the relative speed between A and B approaches the speed of light. Consequently, for B there is an infinite Doppler redshift combined with and infinite gravitational blueshift. The net result depends on the rates at which these two infinities are approached, and could be zero, finite redshift or blueshift, or infinite redshift or blueshift.
I maintain that there is finite redshift or blueshift for B with bounded 4-acceleration,
The relative velocity of an observer infalling from infinity is [tex]\sqrt{\frac{1}{r}[/tex], IIRC. Combine that with your formula, you'll find z = 1 at the horizon.
This is not what I get for the speed. Typo? For a derivation of the combined effect (which gives Ich's z result), see
https://www.physicsforums.com/showthread.php?p=861282#post861282.
I'm not sure if the last mathematical line is showing up correctly. The final result should be
[tex]f' = \frac{f}{1+\sqrt{\frac{2M}{r}}}.[/tex]
Yes, 1=2M, of course. But I see that you've calculated and posted all this long before.
Consider another "falling in" observer B in the neighbourhood of a hovering observer A, but with very slightly smaller [itex]r[/itex] than A. ... A has unbounded 4-acceleration, and, if B has bounded 4-acceleration, the relative speed between A and B approaches the speed of light. Consequently, for B there is an infinite Doppler redshift combined with and infinite gravitational blueshift. ..
OK, I think I understand now, thank you. Only a "hovering" observer ever sees infinite blueshift, and a surface-bound observer cannot possibly be hovering if the surface is contracting. Therefore, the contracting surface never sees an infinite effective temperature from the infalling radiation.
EDIT: Furthermore, it is impossible to hover long enough to even see the infinite blueshift, because you need an infinitely strong force to maintain the hovering!
  • · Replies 31 ·
  • · Replies 40 ·
  • · Replies 51 ·
  • · Replies 25 ·
