Distance Traveled By A Car-Kinematics Problem
by haengbon
Tags: acceleration, hard, kinematics, physics, velocity
haengbon
haengbon is offline
#1
Oct29-09, 11:13 AM
P: 38
a car traveling due east on a straight road and accelerates at a constant rate for 10(s) increasing its velocity from rest to 40 m/s. It then travels at a constant velocity for 5s and accelerates at a steady rate for the next 5s to a velocity of 20m/s. It travels at this velocity for 10s and then accelerates rapidly to a stop at a time of 2s. What is the total distance traveled by the car?
All I know is, the answer NEEDS TO BE 770m. I'm trying to find the soltuion :(
2. Relevant equations
none /:)?
3. The attempt at a solution
I tried solving it first by drawing a diagram and then , paired up (40 m/s, 10s), (40m/s,5s) , (20m/s,5s), (20m/s,10s), (v=?,2s)
then, I solved for the acceleration for each with V=Vo + at. after which, I solved for each of their distances with V(^2) = Vo(^2) + 2ad.
for example,
G: 40 m/s , 10s
V = Vo+ at
40 = 0 + a(10)
a = 4 m/s^2
V^2 = Vo2 + 2ad
1600 = 0 + 2(4)d
d = 200 m
I did the same thing with all the others and after reaching (20 m/s,10s), I got 900. I stopped there and didn't solve further cause I thought I wouldn't get the right answer anymore even if I did solve for (v=?,2s) .
Can someone please guide me? :( I need to find out how to solve this because it would most likely be in the exam I need to pass just days away :( It looked simple at first but I'm going crazy solving it O.o
Phys.Org News Partner Science news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
The hemihelix: Scientists discover a new shape using rubber bands (w/ video)
Microbes provide insights into evolution of human language
ApexOfDE
ApexOfDE is offline
#2
Oct29-09, 11:26 AM
ApexOfDE's Avatar
P: 122
Do you double-check your calculation? If yes but you still have wrong answer, please post your full solution.
rl.bhat
rl.bhat is offline
#3
Oct29-09, 11:27 AM
HW Helper
P: 4,442
Draw the time-velocity graph.
To find the total distance traveled by the car, find the area bounded by the graph with x-axis. It contains 2 triangles, two rectangles and one trapezium.
haengbon
haengbon is offline
#4
Oct29-09, 09:33 PM
P: 38
how do I draw a time-velocity graph :((? I'm sorry but I really don't know how to -___-
haengbon
haengbon is offline
#5
Oct29-09, 09:33 PM
P: 38
Quote Quote by ApexOfDE View Post
I did and I'm sure It's wrong :D I think my formulas is wrong
VelvetRebel
VelvetRebel is offline
#6
Oct29-09, 09:56 PM
P: 17
Are 2 of your accelerations negative? If not, then I believe this is where you are making the mistake. For example, if you are going from 40 m/s to 20 m/s in 5s, this will have a negative acceleration since you are decreasing in velocity.
rl.bhat
rl.bhat is offline
#7
Oct29-09, 09:59 PM
HW Helper
P: 4,442
Take time on x-axis and velocity in y-axis.
Answer to the first part is correct.
For second part, d2 = v*t.
For third part vi = 40 m/s and vf = 20 m/s. Do the calculation as in the first part.
repeat the same thing for reaming parts.
haengbon
haengbon is offline
#8
Oct30-09, 03:48 AM
P: 38
Quote Quote by VelvetRebel View Post
when velocity changes and decreases does that mean it has a negative acceleration? because it's slowing down right?
Quote Quote by rl.bhat View Post
Fro second part, d2 = v*t.
I tried this and it worked :) thank you thank you!
Register to reply
Related Discussions
Simple distance traveled problem Precalculus Mathematics Homework 2
Coeffiecient of Kinetic Friction problem??? (Shuffleboard and Distance traveled) Introductory Physics Homework 1
Pretty simple distance traveled given acceleration problem... Introductory Physics Homework 2
Distance traveled, v->c Advanced Physics Homework 13
distance traveled Introductory Physics Homework 1
