Fred's Simple E-field Sensor: Seeking Suggestions
Fred is designing a simple E-field sensor using two styrofoam balls wrapped in aluminum foil, connected to an oscilloscope via a 100GOhm resistor. Despite his setup, he is unable to measure any potential. Forum members suggest that the sensor may not generate voltage merely by being in an electric field and recommend exploring capacitive pickup techniques for AC measurements or using static charge to measure force for DC fields.
  • Understanding of electrostatics and electric fields
  • Familiarity with oscilloscope operation and measurements
  • Knowledge of capacitive pickup techniques
  • Basic concepts of static charge and force measurement
  • Research capacitive pickup techniques for measuring AC electric fields
  • Explore methods for measuring static charge and its effects on electric fields
  • Learn about electrostatic demonstration devices and their principles
  • Investigate the use of high-impedance resistors in sensor design
Electronics enthusiasts, hobbyists designing E-field sensors, and students studying electrostatics and electric field measurement techniques.
estantef
Hello everyone,
My name is Fred and I'm a newcomer to the forum. I'm designing a very simple E-field sensor. So all I did was I got two styrofoam balls, wrapped them around with a few layers of aluminum foil to serve as charge collecting surfaces. Put both "sensors" on the ends of a thin wood rod about 1m long. Hooked it up to my oscope and measured nothing. Expected, since the potential should be very small anyways. So I connected a 100GOhm resistor in series and then connected to the oscilloscope. Now I should be reading a decent (and somewhat steady) potential.
But that's not happening. Any suggestions or comments?
Thanks a lot,
Fred
estantef said:
Hello everyone,
Thanks a lot,
Fred
Welcome to the PF, Fred. What is the frequency range fjor the E-field that you would like to measure?
If DC, then if you can put some known amount of static charge on an object, you could devise a way to measure the force F=qE to give you the E field info. If AC, you can use some capacitive pickup techniques...
What forms of E-field measurement have you found by searching the web or in books?
There is no reason that such an arrangement would give you a reading on an oscilloscope.
Why do you think it would?
It is very similar to a demonstration device used to show repulsion of electrostatic charges.
You touch both balls with a charged rod (possibly ebonite or plastic that has been rubbed with cat's fur). They both acquire the same charge if they are touching and then tend to repel each other by flying apart. Gold leaf and moving vane electroscopes work on the same principle.
But, they do not generate any voltage themselves just by being in an electric field.
  • · Replies 17 ·
  • · Replies 16 ·
72K
