Several Questions on Electric Potential
The discussion focuses on calculating electric potential and surface charge density for specific configurations. For a thin rod of length 2L with a uniform charge Q, the potential V along the y-axis requires integration with limits from -L to L, utilizing the relationship between electric field and potential. The second question addresses a conducting sphere of diameter d charged to voltage V, where the surface charge density sigma can be derived from the electric field equations, specifically E_{outside shell} - E_{inside shell} = \frac{\sigma}{\epsilon_0} \vec n.
  • Understanding of electric potential and electric field concepts
  • Familiarity with calculus, particularly integration techniques
  • Knowledge of charge distributions and their effects on electric fields
  • Basic principles of electrostatics and Gauss's law
  • Study the derivation of electric potential from electric field using integration
  • Learn about charge distribution types and their impact on electric fields
  • Explore Gauss's law applications for calculating electric fields around conductors
  • Investigate the relationship between surface charge density and electric field strength
Students and professionals in physics, electrical engineering, and anyone studying electrostatics or working with electric potential and charge distributions.
Divergent13
Hey everyone, I just wanted to ask these two questions on electric potential that are having me a bit stuck:
A thin rod of length 2L is centered on the x-axis on a coordinate plane... The rod carries a unif. distr. charge Q. Determine the potential V as a funct of y for the points along the Y axis.
My problem with this--- its not an infinite rod! I understand that since this rod is of specified length, we will have to some tricky math here and end up doing an integral with our limits for the rod (IE -L and L)... but would all this be is essentially the equation one can derive for the same situation for ELECTRIC FIELD, and just multiply by r? (Where r is the dist on the y axis)
Another Question is suppose a conducting sphere of diameter d is charged to a certain voltage V relative to V = 0 at r = infinity.
How can we find an equation sets up the surface charge density sigma?
(Just in general)
I appreciate any help thanks.
Electric Field:
[tex]\def\vr{\mathord{\vec r}} \providecommand{\abs}[1]{\lvert #1 \rvert}<br /> \vec E (\vr) = \frac{1}{4 \pi \epsilon_0}\int\frac{\rho(\vr\ ')(\vr-\vr\ ')}{\abs{\vr-\vr\ '}^3}d l'[/tex]
Electric potential:
[tex] \def\vr{\mathord{\vec r}} \providecommand{\abs}[1]{\lvert #1 \rvert}<br /> &\phi(\vr)=\frac{1}{4\pi\epsilon_0}\int \frac{\rho(\vr\ ')}{\abs{\vr-\vr\ '}}d l '[/tex]
And for the 2nd prob
[tex]E_{outside shell} - E_{inside shell} = \frac {\sigma}{\epsilon_0} \vec n[/tex]
Where n is the unit normal vector pointing out of the shell
Excellent that first one makes perfect sense now--- thank you.
  • · Replies 58 ·
  • · Replies 33 ·
