Physics II Lab - Fizeau's Experiment - Speed of Light
In summary, the light wave must travel 17.3 km or 17300 meters. The goal was to see what frequency was required to get the light to pass correctly through a gap in a wheel. Experimentally, the frequency was found to be 2200 Hz.
dmullin4
I know that the light wave must travel 17.3 km or 17300 meters.
I found experimentally that the frequency should be 2200 Hz. I picked it from a pool ranging from 0 Hz to 5600 Hz. The goal was to see what frequency was required to get the light to pass correctly through a gap in a wheel.
I am asked to use the data gathered to calculate "your speed of light."
speed of light = wavelength * frequency
c = (lambda)*f
I am assuming it is supposed to be around the actual speed of light which is 2.99x10^8 m/s. I am getting a value of 3.806x10^7 m/s by multiplying 17300 m by 2200 Hz.
Am I using the wrong values? Is there some constant I am overlooking that I need to throw in? Is there another equation?
You are assuming that the wavelength of the light is 17.3 km... does that make sense?
I think you might need to describe the context of this question in more detail.
Here is the information page from the lab experiment. There is nothing mentioned about wavelengths or frequencies, except what I figured out that the wheel needs to turn at 2200 rev/s.
Fizeau’s experiment
A light source sends a beam of light toward a partially silvered mirror. The partially silvered mirror splits the light beam, so part of the beam is reflected perpendicular to its original direction and heads outward (to the right). This outward beam passes through one of the gaps in a rotating toothed wheel, hits a flat mirror, and is reflected back towards the wheel. If the wheel is rotating at the right speed, the reflected beam can pass back through a gap in the wheel to be seen by the observer.
Although Fizeau’s original experiment used a toothed wheel with 720 gaps, this animation only used 8 gaps. The round-trip distance from the wheel to the flat mirror and back again is 17.3 km, the same as in Fizeau’s setup. Can you use Fizeau’s experiment to determine the speed of light?
It is not wavelength/frequency problem, it is simple time, speed, distance.
Ok, so I have the distance. Where do I get the time and speed? Its a red light, so I know that's a specific wavelength, but will it be similar to the speed of light at 2.99x10^8 m/s?
Thank God for Youtube.
I found an equation off a video of Fizeau's experiment on Youtube that gave me the equation:
v = 2*d*N*f
which is velocity = 2 * distance between mirrors * number of teeth on wheel * frequency
Plugging all this in, I got 3.04x10^8 which is pretty darn close to the speed of light. At least I'm not off by a magnitude of 10!
I think it is faster to derive this equation from known data, than to google it. For the light to get through time it spends traveling to mirror and back must be identical to the time needed for next teeth (or rater slot between) to come to the same place. N*f is just a frequency at which the slots appear in the same position - and 1/(N*f) is a period. If light passes through it means it made 2*d in one period, so total distance traveled in 1 sec is 2*d*N*f.
What is Fizeau's Experiment?
Fizeau's Experiment is a laboratory experiment designed by French physicist, Hippolyte Fizeau, in 1849 to measure the speed of light.
How does Fizeau's Experiment work?
The experiment involves a beam of light being directed towards a rotating toothed wheel. The light passes through the gaps in the wheel and is then reflected back. By measuring the amount of time it takes for the light to travel through the wheel and back, the speed of light can be calculated.
Why is Fizeau's Experiment important?
Fizeau's Experiment was one of the first successful attempts to accurately measure the speed of light. It provided a more precise value for the speed of light, which was crucial for advancing our understanding of the nature of light and its role in the universe.
What is the speed of light according to Fizeau's Experiment?
Fizeau's Experiment determined the speed of light to be approximately 313,000,000 meters per second, which is very close to the currently accepted value of 299,792,458 meters per second.
How has Fizeau's Experiment impacted the field of physics?
Fizeau's Experiment has had a significant impact on the field of physics, particularly in the study of light and its properties. It has also been used to verify the theories of special relativity and has paved the way for further experiments and advancements in the study of light and its behavior.
