Why is the direction of the dipole moment always taken from -q to +q?
The discussion revolves around the convention of the dipole moment direction in electric dipoles, specifically why it is defined as pointing from the negative charge (-q) to the positive charge (+q). Participants are exploring the implications of this convention in relation to electric field lines and potential energy in dipoles.
  • Participants are questioning the rationale behind the dipole moment convention and its apparent contradiction with the direction of electric field lines. Some are attempting to clarify the definitions and relationships between dipole moment and potential energy.
The discussion is active, with various participants providing insights into the definitions and implications of the dipole moment convention. Some have offered explanations regarding the mathematical definition of dipole moment, while others are seeking further elaboration on these points.
There are references to the potential energy of a dipole in an electric field and the implications of defining the dipole moment in different ways, indicating that the discussion is considering the effects of conventions on physical interpretations.
ananthu
Can anyone explain why the direction of the dipole moment of an electric dipole is always taken as "from -q to +q" but not "from +q to -q"? In fact when we draw the electric lines of force we are only drawing in such a way that they start from +q and terminate at -q.Then why this contradiction? What is the correct explanation for this convention?
It's just a convention.
What does that have to do with the definition of dipole moment? There's no contradiction.
But why is the convention for a dipole the opposite to the other convention? :confused:
Ah... now I understand the question. The "natural" definition of dipole moment (the first moment of the charge distribution) is:
[tex]\vec{p} = q_1\vec{r}_1 + q_2\vec{r}_2[/tex]
That will give the direction of the dipole moment as minus to plus.
When you keep a dipole in an electric field, it acquires the stable equilibrium position with positive charge toward the electric field. Potential energy for a dipole is given by
U = - p.E
It has minimum value = -pE at the stable equilibrium position. It is possible only when p is parallel to E, i.e. p is from -q to +q.
U = - p.E
But if you defined the dipole moment with the opposite convention, U = p.E. And the minimum value would be when p is anti-parallel to E. The physics wouldn't change. (Not that I'm suggesting one flout convention. :wink:)
Will you please elaborate this point?
I'll try. Let q1 = +q and q2 = -q, then:
[tex]\vec{p} = q_1\vec{r}_1 + q_2\vec{r}_2 = q\vec{r}_1 - q\vec{r}_2 = q(\vec{r}_1 - \vec{r}_2)[/tex]
The vectors r1 and r2 are the position vectors of +q and -q. Thus the vector r1 - r2 points from -q to +q.
Thank you. Now it is clear.
  • · Replies 25 ·
  • · Replies 17 ·
