| Thread Closed |
Pressure on sides and ends of pool, given the pools dimensions and depth |
Share Thread | Thread Tools |
| Nov1-09, 09:35 PM | #1 |
A swimming pool has dimensions 34.0 m 9.0 m and a flat bottom. When the pool is filled to a depth of 2.30 m with fresh water, what is the force caused by the water on the bottom? I have the answer to this which is 6.90 x 10^6, however I cannot figure out the pressure on the sides or ends. 2. Relevant equations Pressure on bottom = water density X gravity x area 3. The attempt at a solution I understand the water depth has to play into this somehow but I cannot figure out how... I attempted 9.80 x 2 x 9 = 176.4 kN and 9.80 x 2 x 34 = 666.4 kN These were incorrect |
| Nov1-09, 09:56 PM | #2 |
Recognitions:
Your relevant equation is wrong.
Check it. |
| Nov1-09, 10:16 PM | #3 |
Apologies,
ρ = density - P = pressure - F = force - b = bottom of pool - z = area of pool Pb = ρgz Fb = PbA |
| Nov1-09, 10:40 PM | #4 |
Recognitions:
z is the depth of the water. Now find the pressure at the bottom Pb and then Fb
| Thread Closed |
| Thread Tools | |
Similar Threads for: Pressure on sides and ends of pool, given the pools dimensions and depth
| Ray Refraction: Finding the depth of a pool | Introductory Physics Homework | 2 | ||
| [SOLVED] Force on the sides of a swimming pool, differeniation | Introductory Physics Homework | 13 | ||
| Water depth pressure against air pressure | Classical Physics | 1 | ||
| Help - Pressure of a Pool on concrete | General Engineering | 6 | ||
| Pressure and depth problem | Introductory Physics Homework | 1 | ||
