Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Engineering > General Engineering
Reply
image Question about refrigeration Share It Thread Tools Search this Thread image
Old Nov2-09, 12:20 AM                  #1
Green Zach
Green Zach is Offline:
Hello, I am a first year engineering student and I have a short question about refrigeration systems. Just want to clarify that this is not a homework question. Yes I do think about things like this in my spare time its just personal interest. I'm taking engineering for a reason . Anyways i was wondering if placing a cold object on the condenser/receiver side of a refrigeration system would increase or decrease the efficiency of the system as a whole. I suspect that it would increase the efficiency because if the refrigerant is colder in the condenser (because the cold object would cool the refrigerant down) then my logic says it should condense faster (which, from what I have gathered, is the point of the condenser) and be colder when it is condensed so when it expands in the low pressure portion of the system it should get colder than it would have otherwise. Overall result is less energy input required to run the system. This makes sense to me but I just wanted a second opinion because like I said i am a first year engineering student so I accept that it is very possible for me to be completely wrong about this sort of thing. Just FYI i am not suggesting we all cool things down in our refrigerators then place the cold objects on the warm parts at the back of our refrigerators because in a best case scenario you would be wasting your time because the overall energy use of the system would be the exact same but in a real life scenario you would actually be wasting energy. the purpose of the question is to see if I understand this relationship of the system correctly.
Old Nov2-09, 02:17 AM                  #2
ank_gl
ank_gl is Offline:
Re: Question about refrigeration
We dont generally talk in terms of efficiency for refrigeration system, there is another term called "Coefficient of perfromance" or CoP for short(thats just the convention).
Anyways coming to your observation, you are right, colder the space around the condenser, colder is the refrigerant at the condenser outlet & hence at the evaporator inlet, and the specific refrigeration effect per unit work is increased, or in other words, work required per unit referigeration effect is decreased, or in still other words, CoP is increased.
But how cold can you make the condenser side space?
Old Nov2-09, 02:57 AM                  #3
NeuronsAtWork
NeuronsAtWork is Offline:
You are correct in your understanding. In real-life applications, there are two very common ways that this is put into practice. The first is called a 'precooler', and it is essentially an evaporative cooling pad with associated pump and reservior placed some short distance from an outdoor, air cooled condenser coil on a typical A/C system. The air that passes through the precooler is cooled through evaporation, and that in turn cools the condenser and lowers the high-side refrigerant pressure. Hence, the compressor has less work.
Another common method is the use of a water-cooled condenser. Cool water is piped through a heat exchanger; the other side of the exchanger holds the refrigerant to be condensed. The water, after absorbing heat from the refrigerant, is pumped to a cooling tower where it is cooled through evaporation and returned to the condenser.
Old Nov2-09, 03:56 AM                  #4
defunc
defunc is Offline:
Soon you'll learn of the second law of thermodynamics. This will enable you to investigate things like these in a very quick and elegant way, especially closed cycles.
Old Nov2-09, 09:25 AM                  #5
Green Zach
Thanks you guys are awesome :D! I totally appreciate your help.
Old Nov2-09, 02:33 PM                  #6
dr dodge
dr dodge is Offline:
I have noticed that all my window A/C units now use the water off of the evaporator to aid in cooling the condensor. They don't have drains like the old ones did, so I assume (oh, OH...) that the additional cooling is how the energy efficiency or CoP( ...yes, I learned something) is increased.
but, Zack, you didn't answer, ank_gl, how cold...
dr
Old Nov2-09, 04:37 PM                  #7
sgehrenberg
sgehrenberg is Offline:
There are some interesting new approaches for air conditioning and refrigeration.
My company the Dais Analytic Corporation is developing one that uses a specialized membrane and water vapor. An explanation can be found on the daisanalytic.com website.
image image
Reply
Thread Tools
Similar Threads for: Question about refrigeration
Thread Thread Starter Forum Replies Last Post
Help with refrigeration properties table VooDoo Mechanical Engineering 1 May4-09 03:58 PM
Question about the refrigeration cycle LennoxLewis General Physics 4 Apr12-09 06:55 PM
Refrigeration question eaboujaoudeh General Engineering 3 Jun17-07 09:31 AM
Thermoacoustic Refrigeration bags General Engineering 11 May14-07 11:35 PM
Steady state refrigeration Bonulo Advanced Physics 1 May13-06 09:37 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
