Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Engineering > Materials & Chemical Engineering
Reply
image Fluid flow, pressure drop simulation in Comsol Share It Thread Tools Search this Thread image
Old Nov4-09, 11:27 AM                  #1
baranii2000
baranii2000 is Offline:
Dear all,
I am trying to solve a simple model with Comsol to find the pressure drop in a rectangular channel W=5mm, h=0.6mm, L=10mm. When i try to set the inlet velocity to 0.5m/s the solver shows the error message "Maximum number of newton iterations reached". The solver works fine if i set the input velocity to lower velocity(eg., 0.005m/s). when i increase the velocity to 0.05 m/s the solver ends up with the error message. I even tried to increase the height of the channel, still get the same error sequence.
I am using a Stationary, Direct (Pardiso)solver.
Any comments or help is much appreciated.
Thanks in advance
Arun
image image
Reply
Tags
comsol, fluid flow, microchannel, pressure drop
Thread Tools
Similar Threads for: Fluid flow, pressure drop simulation in Comsol
Thread Thread Starter Forum Replies Last Post
Pressure Drop Across Radiator And Air Flow KLoux Mechanical Engineering 9 Jul1-09 12:32 PM
Pressure Drop Due to Combining Flow in a Water Pipe System metalhead10 Mechanical Engineering 8 May14-09 10:06 PM
Calculate the individual flow rate - based on the pressure drop? peet_dk Mechanical Engineering 0 Apr3-09 06:11 AM
how to use flow rates (GPM) and pressure drop to determine if a valve is usefull MoonKnight General Physics 7 Feb2-09 12:33 PM
Hello, fluid flow simulation KMCB1234 General Physics 13 May22-05 05:59 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
