| Thread Closed |
PROJECTILE MOTION - Given values are Horizontal & Verticle distance when time = 4s |
Share Thread | Thread Tools |
| Nov5-09, 05:32 AM | #1 |
An object fired with a velocity of Vo covers a verticle distance of 20.0m and a horizontal distance of 25.0m in the 4th second of its motion. Determine the following: a) Its velocity of projection, Vo (the rest im not going to worry about cos if i get part a) started then i should be fine i just dont know what im doing wrong) 2. Relevant equations ucosθ = x usinθ = y v = u + at2 s = ut + 1/2at2 v2 = u2 + 2as v = s/t 3. The attempt at a solution ok so i've tried many a times but i think i have a misconception or not seeing what is happening etc. i know the answer as it is given which is Vo = 59.8 m/s 65.3o (angle between ground and vector) so it takes 4 seconds for the projectile to be displaced horizontally by 25 m so by v=s/t v=25/4 v=6.25 which v is also known as x so i have x=6.25 m/s the verticle velocity i found by many ways or tried to but heres one way s=ut + 1/2at2 s = 20 a = -9.8 t = 4 20 = 4u + 1/2.(9.8).42 98.4 = 4u u = 24.6 m/s and in this case u = y so y=24.6 by pythagoras Vo2 = y2 + x2 Vo2 = 24.62 + 6.252 Vo = 25.2815 clearly not the answer but i proceeded to find the angle y = usinθ θ = 14.255 angle between ground and vector = 90 - 14.255 angle = 75.745 degrees which is clearly not the case if you see where ive gone wrong please do tell :) ive tried many many wasy of getting the projected velocity and nothing seemed to work, ive tried 4 times and that takes a long time |
| Nov5-09, 05:53 AM | #2 |
sorry i used all caps for the topic, diddnt read the rules properly till it was too late, i do not wish to offend anyone soz
| Nov5-09, 07:41 AM | #3 |
I don't know, but I did the exact same thing as you.
| Nov5-09, 08:15 AM | #4 |
me too. theres seems to be nothing wrong with your method. i cant think of another way of doing it
| Nov6-09, 12:01 AM | #5 |
yeah i found out what was wrong
it says in the 4th second meaning between t=3 and t=4 so it takes 1 second for the ball to reach 20m high and 25m horizontally haha damn english, ill post the answers soon |
| Nov6-09, 06:24 PM | #6 |
An object fired with a velocity of Vo covers a verticle distance of 20.0m and a horizontal distance of 25.0m in the 4th second of its motion.(Meaning second 3 to second 4) Determine the following: a) Its velocity of projection, Vo (the rest im not going to worry about cos if i get part a) started then i should be fine i just dont know what im doing wrong) 2. Relevant equations ucosθ = x usinθ = y v = u + at s = ut + 1/2at2 v2 = u2 + 2as v = s/t 3. The Solution Vertical Velocity s = ut + 1/2at2 when t=3 s1 = 3u + ½ X (-9.8) X 32 when t=4 s2 = 4u + ½ X (-9.8) X 42 s2 – s1 = 20m s2 – s1 = (4u + ½ X (-9.8) X 42) – (3u + ½ X (-9.8) X 32) 20 = 4u – 78.4 – 3u + 44.1 20 = u – 34.3 u = 54.3 m/s let u = y y = 54.3 m/s Horizontal Velocity v = s/t v = 25/1 v = 25 m/s let v =x x = 25 m/s Vo Vo2 = y2 + x2 Vo2 = 54.32 + 252 Vo = 59.779 m/s tanθ = 54.3/25 θ= 65.278o Therefore Vo = 59.779 m/s 65.278o (angle of elevation) |
| Thread Closed |
| Thread Tools | |
Similar Threads for: PROJECTILE MOTION - Given values are Horizontal & Verticle distance when time = 4s
| Finding Horizontal Distance in Projectile Motion | Introductory Physics Homework | 1 | ||
| Projectile Motion: Given Horizontal Distance Travelled and Time Taken | Introductory Physics Homework | 1 | ||
| horizontal/verticle distance, velocity | Introductory Physics Homework | 2 | ||
| [SOLVED] Finding time up and time down: Verticle Projectile | Introductory Physics Homework | 3 | ||
