Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Engineering > Electrical Engineering
Reply
image "Grounded" Electricity Share It Thread Tools Search this Thread image
Old Jul15-04, 05:40 AM                  #1
FinalAvenger
FinalAvenger is Offline:
Well I've checked a few sites for the answer but I still don't seem to understand the grounding as well as I'd like to. I understand that it literally means a wire that goes into the dirt. What I don't understand is where the electrons go after that. Or what they are doing in a socket before you plug something in.
Lets say we were talking about water. If you "grounded" water, it would just sit there and get soaked up and eventually go away. When you arn't using a spicket, the water is sitting there waiting to be used. But before you plug something in, is the electricity sitting there at the end of the wire or is it moving elsewhere? Thanks.
Old Jul15-04, 08:47 AM                  #2
rayjohn01
rayjohn01 is Offline:
Grounding allows a current ( temporary) to flow between the object and ( earth , water pipe, etc.) IF there were a voltage between them -- like discharging a capacitor,
This ensures that the volt difference is close to zero to eliminate accidental shock.
The Main AC supply has one conductor close to ground ( third prong) it is this one which must be used for internal 'grounding of cases etc. , but in many instances there is no ground wire( two prong) but one is close to ground potential.
Don't play around with this if your not sure.
Grounding of RF equipment has to do with antennas, the earth acts like a large slightly imperfect mirror and vertical antennas form half the total ( the mirror the rest ) which is why many such antennas are 1/4 wave as opposed to what they should be 1/2 wave. ray.
Old Jul15-04, 01:23 PM                  #3
chroot
PF Admin
chroot's Avatar
chroot is Offline:
Ordinarily the ground wire does absolutely nothing. No electrons flow through the ground wire at all under normal circumstances. Remember that only a few decades ago plugs only had two prongs, with no ground.
The ground wire is important only for safety reasons. I'll quote from howstuffworks.com:
The idea behind grounding is to protect the people who use metal-encased appliances from electric shock. The casing is connected directly to the ground prong.
Let's say that a wire comes loose inside an ungrounded metal case, and the loose wire touches the metal case. If the loose wire is hot, then the metal case is now hot, and anyone who touches it will get a potentially fatal shock. With the case grounded, the electricity from the hot wire flows straight to ground, and this trips the fuse in the fuse box.
http://electronics.howstuffworks.com/question110.htm
- Warren
Old Jul15-04, 01:43 PM                  #4
rayjohn01
Actually 'ground wires' are quite active they are subject to induced voltages from nearby equipment - radio waves , static electrical discharges , lightening and so on -- there is no such thing as a perfect ground , and some 'ground wires have enough voltage to give you a shock -- not usually lethal tho'. Ray
Old Jul15-04, 02:08 PM                  #5
chroot
PF Admin
chroot's Avatar
chroot is Offline:
What you've said about ground wires is true for all wires. Although true, it's not particularly relevant to the discussion.
- Warren
Old Jul15-04, 02:30 PM       Last edited by rayjohn01; Jul15-04 at 02:35 PM.. Reason: add            #6
rayjohn01
You can choose to ignore , but in my opinion we are talking about the meaning of grounding and what a ground wire is like I believe is relevant.
If youve ever seen the result on equipment of a ground surge you may think differently.
It is not always true that active wires are treated in the same way as ground wires hence they can be subject to very different conditions. Not only that but you cannot assume all wires are balanced to common mode surges which are often ground induced without connection.
How many other topics would you like to ignore . Ray.
Old Jul15-04, 03:47 PM                  #7
chroot
PF Admin
chroot's Avatar
chroot is Offline:
rayjohn,
The original poster simply asked what a ground wire is intended to do -- that question has been answered. Please stay on-topic. Advanced topics like lightning-strike induced ground surge and RF interference just aren't relevant here.
- Warren
Old Jul15-04, 04:20 PM                  #8
FinalAvenger
- Warren
From 2 pm to about 2 in the morning yesturday, all I was doing was reading electricity articles on HSW haha. It's so interesting and of course I read that article as well. But I was just thinking that it seems electricity needs to go in a "circuit" but when it goes to the "ground.".. Where's the circuit in that? Does it just go and disperse the electrons in the dirt?
Old Jul15-04, 04:27 PM                  #9
Njorl
Njorl is Offline:
Recognitions:
There's a saying in circuits, "Grounds of the world unite".
So, if you see a circuit diagram with a power supply and a device, and the hot side of the supply goes to the device, and both the supply and device also go to ground, there is a circuit, because the grounds are considered shorted to eachother.
Beware though. In practice, grounds can have slight differences. It isn't enough to hurt anybody, but if your measuring small AC signals, ground loops can ruin hours of data.
Njorl
Njorl
Old Jul15-04, 07:30 PM                  #10
megashawn
megashawn is Offline:
Recognitions:
Lemme take a crack at it.
Think of an automobile. Think of the charging system. Generally, the battery which has a positive and negative, has two connections. The negative terminal is attached to the chassis of the car, while the positive connects to all the various powered items.
If you were to take a light bulb, attach a wire to one terminal on the bulb, and the other end of the wire to the positive, nothing would happen.
Now, touch the second terminal of the bulb to any metal part of the automobile and current flows from the battery, through the chassis, and into the bulb.
In this case, the chassis of the car is considered grounded, although it is not connected to the ground. Grounding is basically a term, and while yes homes generally have a ground point somewhere that is planted in the earth, as was mentioned, this is merely for safety purposes.
Now, a neat trick is to find a nice healthy tomato plant and a multimeter, plug the positive probe of the meter into the plant, somewhere near the top, and put the negative probe in the dirt. Set the multimeter to measure low dc volts, and you should see some numbers, representing the voltage present in the plant.
It isn't like every electrical device is plugged into the ground, it is more like a method of requiring less wire/circuit traces. In an automobile, and DC device can be powered simply by attaching a positive wire to it, and another which is attached to any bare metal.
Consider a car stereo. You run a power wire, usually from the fuse box, but we will say from the positive of the battery. Now, if your antenna is properly installed, it serves two purposes. One is to pick up radio channels, and the other grounds your stereo to the chassis of the car. This completes the circuit and allows you to power on your stereo.
Some of the older, cheaper stereos out there use a thing that is called "Common Grounding" And a two speaker stereo system will only have 5 wires, 1 power(positive), 1 ground(negative), Right speaker positive, left speaker positive, speaker ground.
In this case, you would install the stereo as I mentioned above, you can attach the ground wire for extra elimination of road noise if needed. To install the speakers, you run one wire from the Left + and one from the Right + to the respective speakers. Then, you can run a single wire to both speakers.
Old Jul15-04, 07:51 PM                  #11
chroot
PF Admin
chroot's Avatar
chroot is Offline:
Car stereos are not grounded through the antenna.
Running speaker return current through the chassis is a guaranteed way to make your stereo sound like crap.
- Warren
Old Jul15-04, 08:22 PM                  #12
rayjohn01
Chassis
Megashawn
you sometimes also see a wire trailing under the car to scrape the 'ground' this is literally to ground the car chassis since in dry weather it can build up static of 10's of thousands of volts giving quite a sharp shock on leaving the vehicle. Here the car and the real ground act as a capacitor -- the wire discharges it by conducting electrons from one to the other . Ray
Old Jul16-04, 02:17 PM                  #13
Njorl
Njorl is Offline:
Recognitions:
Originally Posted by rayjohn01
Megashawn
I remember as a kid, all the cars and trucks had them. Now, I almost never see them. I live in DC, where it is not dry at all (it is a stinking swamp). Do they have them in drier areas still?
Njorl
Old Jul16-04, 02:54 PM                  #14
rayjohn01
Brrrr
To Njorl
I live in Canada Njorl where it varies from being hot and humid to being cold and very dry. Yes they still use grounding wires as the shocks can be really sharp , one trick is to use a Key to touch the metal rather than a finger. :surprise:
Old Jul16-04, 04:03 PM                  #15
Gokul43201
Gokul43201's Avatar
Gokul43201 is Offline:
Recognitions:
PF Contributor PF Contributor
Retired Staff Retired Staff
Njorl
I concur ! Establishing "true" single point ground can be a real hard problem to solve. We had to spend weeks redigning/implementing our grounding scheme because of picovolt noise that came from someone buying soda from the coke machine behind our lab.
Old Jul16-04, 07:51 PM                  #16
megashawn
Recognitions:
I can assure you the car stereo I'm using right now begs to differ.
image image
Reply
Thread Tools
Similar Threads for: "Grounded" Electricity
Thread Thread Starter Forum Replies Last Post
Difference between "Identical", "Equal", "Equivalent" XxnecroxX Calculus & Beyond 9 Apr11-09 09:14 PM
Current Electricity: Help understanding concept of "potential energy" pugfug90 Introductory Physics 18 Feb22-07 11:28 AM
An "invisible wall" created by static electricity? RGClark General Physics 4 May13-05 02:00 PM
Saving 'classic' Phys/Math textbooks (was- What does it mean that "Pc 523 or Dw 868.4" in Smythe, William R. 's <Static and dynamic electricity>) J. J. Lodder General Physics 1 Apr16-05 09:03 PM
Re: What does it mean that "Pc 523 or Dw 868.4" in Smythe, William R. 's <Static and dynamic electricity> Todd General Physics 1 Apr8-05 03:22 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
