Turn Off Vocals in Songs | Winamp Tips and Tricks
  • Thread starter Thread starter MathematicalPhysicist
The discussion revolves around methods to remove or reduce vocals from songs using Winamp and other techniques. Participants explore various approaches, including plugins, studio cuts, and hardware solutions, while addressing the limitations and challenges associated with vocal removal.
  • Some participants suggest that obtaining a studio cut of a song is the most effective way to eliminate vocals, as once the tracks are merged, separation becomes difficult.
  • Others propose using a good EQ plugin to drown out vocals, though this may also affect other parts of the music.
  • A participant shares a link to a plugin called AnalogX Vocal Remover, which can be used with Winamp, and provides installation instructions.
  • Another participant describes a hardware method involving a differential amplifier to cancel out vocals, noting that success depends on the stereo signal and that some vocals may still be audible.
  • There is a suggestion to obtain instrumental versions of songs as an alternative to removing vocals.
Participants express varying opinions on the effectiveness of different methods for vocal removal, with no consensus on a single best approach. Some methods are acknowledged to have limitations, and the discussion remains unresolved regarding the most effective technique.
Participants mention that the effectiveness of vocal removal techniques can depend on the specific audio tracks and the tools used, highlighting the complexity of the task.
Individuals interested in audio processing, music production, or those looking to modify songs for personal use may find this discussion relevant.
how can you shut down the vocals in songs?
Computer science news on Phys.org
Hmmm, maybe there is a plugin for winamp, but I've never heard of anything that does what you want.
I think pretty much the only way to do that is to obtain a studio cut of the song, before they have merged the vocal and instrument tracks. Once they are merged, I don't know what you would use to separate them.
I don't know that you can, but perhaps with a good EQ plugin you could drown it out a good bit. You usually lose some part of the music as well though.
Lemme know if you figure anything out, I've been wanting to do that for years.
Like was mentioned, usually once there mixed, there stuck.
In order to use this plugin, you must have WinAmp 2.0 or greater installed. It
also requires a stereo stream to work properly, and the higher the bitrate the
better. To enable it, just go into the Preferences (CTRL-P), and select
'AnalogX Vocal Remover' from the list; a slider will appear on the screen that
will allow you to adjust the amount of the effect (0% = normal; 100% = totally
processed).
The most common problem people have when installing the program is putting it
in the wrong directory. If it doesn't show up in the WinAmp program, simply
search your system for the file 'dsp_vr.dll' and copy it into the
WinAmp/Plugins directory.
this is from the readme file. I think I might have a standalone version on my home computer. I haven't actually used it.
Raavin
If you are not using a computer to do all of this, you can accomplish the task by running the stereo lines into a differential amplifier and making use of the monophonic output. The inverting and noninverting inputs of an operational amplifier, on which this type of circuitry is generally constructed, give you the desired phase shifting where the center stage (the 'place' where vocals usually are located on a recording, but not always) is canceled out as common mode noise. The success is largely dependent upon the nature of the stereo signal it is being fed, and you will often hear at least a trace of vocals, though about 60dB of attenuation is possible. Because the output often has high levels of ambience signals, if you amplify it and drive a couple of speakers placed at the back of the room you can create a sort of ‘poor-mans’ quadraphonic system.
If you like to build kits I might be persuaded to whip you up a schematic…
try to get the instrumentals for the song u want
  • · Replies 16 ·
