Angular Velocity of a turntable after weights are added
by doneganstm
Tags: added, angular, turntable, velocity, weights
doneganstm
doneganstm is offline
#1
Nov7-09, 12:46 PM
P: 1
A 2.0 {\rm kg}, 20-cm-diameter turntable rotates at 100 {\rm rpm} on frictionless bearings. Two 500 {\rm g} blocks fall from above, hit the turntable simultaneously at opposite ends of a diagonal, and stick. What is the turntable's angular velocity, in rpm, just after this event?
I'm not quite sure on how to set this one up or what equation to use, can anyone give me a push in the right direction?
Phys.Org News Partner Science news on Phys.org
Simplicity is key to co-operative robots
Chemical vapor deposition used to grow atomic layer materials on top of each other
Earliest ancestor of land herbivores discovered
tiny-tim
tiny-tim is offline
#2
Nov7-09, 03:30 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,167
Hi doneganstm! Welcome to PF!
Hint: conservation of angular momentum.
Register to reply
Related Discussions
angular velocity for a turntable Introductory Physics Homework 2
Angular Velocity of a turntable-man system Introductory Physics Homework 3
Disk (horizontal axis) with string added masses... angular velocity after 2 seconds? Introductory Physics Homework 2
Turntable, block, and rotation angular velocity Introductory Physics Homework 2
Pulley w/ attached weights/Linear+Angular acceleration. Introductory Physics Homework 6
