Charge density in terms of (r,θ) but need it in terms of the vector r'
The discussion revolves around a problem involving a sphere of radius R with a specified charge density in spherical coordinates. The original poster seeks to express this charge density in terms of a different coordinate system while attempting to find the potential at points far from the sphere.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to understand the relationship between the charge density expressed in terms of spherical coordinates (r, θ) and the primed coordinates (r', θ'). There is confusion regarding the integration process and the implications of using different coordinate systems. Some participants question the reasoning behind the transformation of coordinates and the assumptions made about the angles involved.
Participants are actively exploring the mathematical relationships and transformations necessary for the problem. There are indications of productive guidance being offered regarding the use of primed coordinates in integrals, although there is no explicit consensus on the correctness of the approaches taken. The discussion remains open with various interpretations being examined.
There are references to potential misunderstandings regarding the integration limits and the nature of the charge density. Some participants express concerns about the validity of external sources for answers, indicating a focus on ensuring the integrity of the problem-solving process.
darkpsi
A sphere of radius R, centered at the origin, carries charge density
ρ(r,θ) = (kR/r2)(R - 2r)sinθ,
where k is a constant, and r, θ are the usual spherical coordinates.
Find the approximate potential for points on the z axis, far from the sphere.
potential of the dipole
V(r,θ) = 1/4πεo * 1/r2 ∫ r'cosθ' ρ(r') dτ'
I just want to know why I'm giving the charge density in terms of r and θ and yet I need it in terms of r'. I know that the vector r' is related to θ' by r' = rcosθ'
So I tried to say that since θ is the inclination from the xy plane and θ' is the angle between r and r' so that θ'+θ = π/2. Then that would give me
sinθ = [(π/2))-θ'] = cosθ'
Since the direction of r' is cosθ' I thought maybe I could replace r with r'?
so maybe
ρ(r',θ') = (kR/r'2)(R - 2r')cosθ' so
ρ(r') = (kR/r'2)(R - 2r') ?
PLEASE help I have a test on this tomorrow..
so maybe
Looks to me that you are confusing yourself on a simple matter. When inside the integral, it is often convenient to use primed-coordinates to separate from the original matter. If you had
[tex] V(r,\theta)=\frac{1}{4\pi\varepsilon_0}\,\frac{1}{r^2}\int r\cos[\theta]\rho(r)d\tau[/tex]
it might confuse you because your limits of integration would also be in terms of [itex]r[/itex] and [itex]\theta[/itex]. The prime markers just show that, inside the integrand, [itex]r'[/itex] is slightly different from [itex]r[/itex], but does become [itex]r[/itex] after integration; this way you have
[tex] V(r,\theta)=\frac{1}{4\pi\varepsilon_0}\,\frac{1}{r^2}\int r'\cos[\theta']\rho(r')d\tau'[/tex]
to tell the difference between what needs to be integrated and what is already taken care of through integration.
so in ρ(r,θ) = (kR/r2)(R - 2r)sinθ, r and θ are bascially r' and θ'?
when I integrate it that way I'm getting
∫ r'cosθ' kR(R-2r')sin2θ' dr'dθ'dφ'
then integrating ∫sin2θ' cosθ' dθ' I get
1/3sin3θ' (0 -> pi) which gives me zero.
And the answer is supposed to be
V(z) = 1/4πεo kπ2R5/(24z2)
What makes you think that?...I also get that the monopole and dipole terms both vanish, and so the dominant term will be the quadrapole term...
That's a pretty sketchy website to be looking for homework solutions...the answer they give doesn't even have the correct units, so that should be a dead giveaway that something is wrong.
Your quadrapole term is a little off...why not show me your calculation?
Here goes:
V(r,θ) = 1/4πεo * 1/r3 ∫∫∫0R (3/2 cos2θ' - 1/2) kRsin2θ' (Rr'2 - 2r'3) dr'dθ'dφ'
= 1/4πεo * 1/r3 ∫∫0π (3/2 cos2θ' - 1/2) kRsin2θ' (-1/6 kR4) dθ'dφ'
| Using 3/2 cos2θ'(cos2θ' - 1)
| = 3/2 (cos4θ' - cos2θ')
| = 3/2 [(1/2 + 1/2cos2θ')2 - cos2θ']
= 1/4πεo * 1/r3 ∫∫0π [3/2 [(1/2 + 1/2cos2θ')2 - cos2θ'] sin2θ' (-1/6 kR4) dθ'dφ'
= 1/4πεo * 1/r3 ∫∫0π 3/2[(1/4 + 1/2cos2θ' + 1/4cos22θ')- cos2θ'] -1/2sin2θ' (-1/6 kR4) dθ'dφ'
= 1/4πεo * 1/r3 (-1/6 kR4) ∫0( 3/2[(θ'/4 + 1/4sin2θ' + θ'/8 + 1/16sin2θ')] - 1/2(θ'/2 - 1/4sin2θ'|0π dφ'
| Since all the sine terms are zero I got
= 1/4πεo * 1/r3 (-1/6 kR4) ∫0( 3/2[(θ'/4 + θ'/8)] - 1/2(θ'/2)|0π dφ'
= 1/4πεo * 1/r3 (-1/6 kR4) ∫0 3/2(-3/8π) dφ'
= 1/4πεo * 1/r3 (-1/6 kR4) 3/2(-3/8π) * 2π
= 3πkR5 / 64εor3 |r=z
= 3πkR5 / 64εoz3
I think there may be a mistake in my use of the half-angle identity?
Why are you using this?
[tex]\left(\frac{3}{2}\cos^2\theta'-\frac{1}{2}\right)=\frac{1}{2}(3\cos^2\theta'-1)=\frac{1}{2}[3(1-\sin^2\theta')-1]=1-\frac{3}{2}\sin^2\theta'\neq\frac{3}{2}\cos^2\theta'(\cos^2\theta'-1)[/tex]
Because I was distributing the sin2 to just that term and then trying to solve that integral. But I see that you're way is much easier. Thanks!
  • · Replies 20 ·
  • · Replies 16 ·
