Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Other Sciences > Chemistry
Reply
image Zinc Oxide reduction Share It Thread Tools Search this Thread image
Old Nov8-09, 09:59 PM                  #1
mheslep
mheslep is Offline:
Recognitions:
PF Contributor PF Contributor
The two commercial methods of reducing ZnO to Zn appear to be
Thermal, in the presence of C:
2 ZnO + C → 2 Zn + CO2
and electrowinning:
ZnO + H2SO4 → ZnSO4 + H2O (followed by electrolysis on the ZnSO4)
But what is the effect of straight electrolysis on ZnO in the presence of some electrolyte to begin with? That is, doesn't electrolysis directly reduce ZnO (as in a charging a depleted Zn-Air battery), and if that's the case why isn't ZnO electrolysis an economic way of producing Zn from ore?
Old Nov9-09, 12:07 AM                  #2
chemisttree
chemisttree's Avatar
chemisttree is Offline:
Recognitions:
Homework Helper Homework Helper
Re: Zinc Oxide reduction
zinc oxide is nearly insoluble in water or non-acidic electrolyte.
I'm not sure about the economics of the two processes you reference. I would imagine the electrowinning process produces very pure material and the carbon reduction would produce less pure product.
Old Nov9-09, 03:05 PM       Last edited by lightarrow; Nov9-09 at 03:11 PM..            #3
lightarrow
lightarrow is Offline:
Probably is possible to get Zn from electrolysis of melted ZnO at high temperatures using a flux, as the way Al is produced from Al2O3 using Na3AlF6 as flux. In the case of Al there is quite no other way (you don't get Al from the oxide reducing it with C and you don't get Al from electrolysis of acqueous solutions of its salts); in the case of Zn the two processes you described are certainly much more simple and cheap, so I presume it's for this reason they are used.
Old Nov9-09, 07:19 PM                  #4
mheslep
mheslep is Offline:
Recognitions:
Probably my OP question is ill phrased. Let me try again.
Given a Zn anode, who's surface is largely oxidized to ZnO, and the ZnO is in contact with some alkaline electrolyte, should not the application of an electric potential to the electrode force reduction of the ZnO? Assume anything you like for the cathode, i.e. air via some porous material:
ZnO + 2e + H2O → Zn(OH)2 → 2OH- + Zn
This is basically a Zinc Air battery being charged. The Zn need never enter solution, and no high temperatures required. It should be inexpensive?
Old Nov9-09, 08:15 PM                  #5
mheslep
mheslep is Offline:
Recognitions:
Oh, I see that's a non trivial amount of charge per kg of Zn:
Zn @ 65g/mole
1 mole e = 96485 C, 3600 C / amp-hour
1 mole e = 26 amp-hours, or
52 amp-hours per mole of Zn,
800 amp-hours per kg of Zn @ 2V = 1.6 kWh per kg of Zn.
That's about $0.12 per kg Zn, with see Zinc @ $2.1/kg, about 6% of the cost. Seems reasonable.
image image
Reply
Thread Tools
Similar Threads for: Zinc Oxide reduction
Thread Thread Starter Forum Replies Last Post
the XRD pattern of Zinc oxide and zinc oxide in acrylic acid !! justinlee Materials & Chemical Engineering 3 May15-08 09:27 AM
Oxidation - Reduction with copper and zinc future_vet Other Sciences 0 Nov5-06 01:06 PM
did zinc react with zinc sulphate solution? yipkawa Chemistry 2 Aug2-06 11:26 AM
Zinc Properties supasupa Engineering, Comp Sci, & Technology 1 Jul30-06 12:08 AM
Pentacoordination of Zinc? chem_tr Chemistry 5 Sep25-04 10:13 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
