We're supposed to measure rise delay and fall delay of the output voltage.
This is a bit ambiguous. It could mean the propagation delay through the inverter or it could mean the rise and fall times of the output waveform.
So, I'll cover both.
See this diagram:
The two waveforms at the left are the input (top) and output (bottom) as viewed on a dual trace oscilloscope. The output will be delayed slightly due to the internal operation of the inverter chip. You measure this on any reasonably vertical portion of both waveforms provided it is the equivalent point on each graph, allowing for the inverting action of the inverter..
This is just to avoid errors due to rounded corners etc.
Rise and fall times are the times it takes for the waveforms to go from 10 % of the full amplitude to 90 % of full amplitude (or the other way around for falling waveforms).
This is shown on the right two diagrams.
