Thread Closed
Deflection of tapered beam cantilever
Share Thread Thread Tools
Nov9-09, 10:09 AM   #1
SJB
Hi and thank you for taking a look at my problem..
I'm very familiar with doing deflection calculations for beams of constant cross-section but I find myself needing to now do calculations on a beam of varying cross-section and I'm completely lost.
It's a relatively simple case in that the beam is a round/tubular, constant/symmetrical taper. It's supported in cantilever at the large end and the load is a single point load at the tip. I've attached a simple sketch if it helps.
As a starting point, is it even possible to derive an equation for the deflection of the beam or can this only be calculated by FEA? (excuse my ignorance!)
If anyone can offer any help/pointers/equations I would be very grateful.
Thanks for your time.
Simon
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Nov12-09, 12:55 AM   #2
This is certainly possible to derive eq'n of delection.
You will need to derive the deflection equation for you case, from equation:
E*I*d2y/dx2 = -M,where I is varying with position of section, and will be a function of x.
Therfore
E*d2y/dx2 = -M/Ix, and integrate this equation twice.
you will need to do this carefully and in the end you will get a big,scary expression of deflection.
You can definitely varify your result with FEA.
Take a look at Roark also for some empirical formula,depending upon ratio of both end area of inertias.
Dec2-09, 02:52 AM   #3
SJB
Hello Piygar,
Thank you for your reply, I'll give this a go and if successful will post back the equation in case it is useful to others.
Thanks
Simon
Dec21-09, 09:47 AM   #4
nvn
Recognitions:
Homework Helper Homework Help
SJB: The cantilever tip deflection would be as follows, with x = 0 at the fixed support.
[tex]y_{\,\mathrm{max}}=\frac{1}{E}\int_{0}^{L}
\int_{0}^{x}\frac{M(x)}{I(x)}\,dx\ dx[/tex]
Thread Closed
Thread Tools
Similar Threads for: Deflection of tapered beam cantilever
Thread Forum Replies
Cantilever Beam Deflection Engineering, Comp Sci, & Technology Homework 5
Tapered cantilever Mechanical Engineering 0
Cantilever deflection Introductory Physics Homework 3
Deflection of Cantilever Beam Arrangement Mechanical Engineering 8
Deflection of Cantilever Beam Arrangement Classical Physics 0
