Register to reply
Momentum Problem
by einsteinette
Tags: momentum
Share this thread:
einsteinette
#1
Nov9-09, 12:32 PM
P: 12
Hello there, I am having difficulty with this question:
A 0.2 kg plastic cart (Cart a) and a 20 kg (Cart b) lead cart can both roll without friction on a horizontal surface. Equal forces are used to push the two carts forward for a distance of 1 m, starting from rest. Which cart has the greater momentum, after the full 1m?
So I was thinking that since you apply equal forces to push the two carts, Cart A would have a higher velocity. But when you do the momentum of the two carts together, the larger mass of cart B would make up for the difference of velocity. If I'm right about the velocity thing that is.
mava = 0.2Va(>vb)
mbvb = 20Vb(<va)
So the momentum would be somewhat equal?
Phys.Org News Partner Science news on Phys.org
Final pieces to the circadian clock puzzle found
A spray-on light show on four wheels: Darkside Scientific
How an ancient vertebrate uses familiar tools to build a strange-looking head
Doc Al
#2
Nov9-09, 01:04 PM
Mentor
Doc Al's Avatar
P: 41,555
Quote Quote by einsteinette View Post
That's true, but you need to figure out how much higher is the velocity of Cart A. Hint: Since equal force is exerted for equal distance, what can you say is the same for the two carts after the push?
einsteinette
#3
Nov9-09, 01:33 PM
P: 12
The force applied and the rate of deceleration?
Doc Al
#4
Nov9-09, 01:39 PM
Mentor
Doc Al's Avatar
P: 41,555
Momentum Problem
The force is the same but the accelerations are not. But you can use Newton's 2nd law and some kinematics to figure out the velocity of each cart after it is pushed. Then you can compare momentum.
But another way is to recognize what force*distance gives you, and use that to figure out the velocity and momentum.
einsteinette
#5
Nov9-09, 01:48 PM
P: 12
Ahh so you mean work done is the same. I think I get it now. Thanks!
Register to reply
Related Discussions
Momentum and Conservation of Momentum Problem Introductory Physics Homework 11
Momentum Problem Introductory Physics Homework 7
HELP w/ momentum problem Introductory Physics Homework 7
Momentum problem Introductory Physics Homework 11
Momentum / Angular Momentum Problem Introductory Physics Homework 0
