Register to reply
Friction force on disk
by holtvg
Tags: disk, force, friction
Share this thread:
holtvg
#1
Nov9-09, 03:24 PM
P: 18
A 3.10 kg, 31.0-cm-diameter disk in the figure is spinning at 300 rpm, how much force must a brake apply that is perpendicular to the rim of the disk to bring the disc to a halt in 2.4 s.
2. Relevant equations
t=i*alpha wf=0+alpha*t t=fr*sin(theta)
3. The attempt at a solution
i=1/2mr^2=.24
wf=0+alpha*t wf=0 w0=300 rpm=31.4 rad/s t=2.4 s alpha=-13.1 rad/s^2
t=i*alpha=-3.1 n*m
t=fr*sin(theta) theta=90 degress
t=fr
-3.1=f*.155 r=15.5 cm=.155 m
f=-20 n
Don't know what i'm doing wrong but it's not the correct answer.
Phys.Org News Partner Science news on Phys.org
'Office life' of bacteria may be their weak spot
Lunar explorers will walk at higher speeds than thought
Philips introduces BlueTouch, PulseRelief control for pain relief
willem2
#2
Nov9-09, 05:28 PM
P: 1,408
Quote Quote by holtvg View Post
i=1/2mr^2=.24
How do you get 0.24 here?
holtvg
#3
Nov9-09, 09:37 PM
P: 18
The i or moment of inertia for a thin disk is given by i=1/2mr^2 where m is the mass of the disk and r is the radius of the disk both in meters.
ideasrule
#4
Nov9-09, 09:41 PM
HW Helper
ideasrule's Avatar
P: 2,322
Except if you plug in the radius and mass, you don't get 0.24.
holtvg
#5
Nov10-09, 10:10 AM
P: 18
sorry calc mistake i=.037
ideasrule
#6
Nov10-09, 01:05 PM
HW Helper
ideasrule's Avatar
P: 2,322
If you plug in i=0.037 you should get the right answer. Do you?
holtvg
#7
Nov10-09, 03:42 PM
P: 18
I get -3.27 n but the correct answer is -3.14 n, probably just a rounding error. But yes i do get the right answer as i messed up in i.
Thankyou
Register to reply
Related Discussions
Rotating disk with friction on the boundary Mechanical Engineering 1
Finding the force of friction acting on an object - static or kinetic friction? Introductory Physics Homework 1
Friction Model for a rolling disk Classical Physics 3
Frictional force of a disk Introductory Physics Homework 10
