How Critical is Magnet Precision in Magnetron Functionality?
  • Thread starter Thread starter Locrian
    Electromagnet
The discussion revolves around the precision required for the electromagnet in a magnetron, particularly in the context of refurbishing a microwave power supply. Participants explore the implications of using a replacement magnet that may not match the original specifications, considering both theoretical and practical aspects of magnetron functionality.
  • One participant expresses concern about the lack of detailed information regarding the specific requirements for the magnet in a magnetron and seeks insights on how variations in the magnetic field might affect performance.
  • Another participant suggests that the magnet may not be critical, noting that simple permanent magnets are used in microwave ovens and that the resonant cavities and anode voltage are more significant factors for frequency and power output.
  • A participant shares their decision to have a local shop wind a new magnet, indicating a practical approach to the problem while acknowledging the risks involved in the refurbishment process.
  • One contributor mentions their experience with orotrons, emphasizing that field continuity is more important than the exact field strength, and raises a question about the condition of pole pieces in relation to the magnet's performance.
Participants express differing views on the criticality of the magnet's specifications, with some suggesting it is not a major concern while others highlight the importance of specific factors like field continuity. The discussion remains unresolved regarding the exact impact of magnet precision on magnetron functionality.
Participants acknowledge varying levels of expertise and experience with magnetrons, which may influence their perspectives. There is also a mention of the potential risks associated with improper repairs, particularly regarding high voltage and safety.
This discussion may be of interest to those involved in microwave technology, electromagnet design, or refurbishment of high-power microwave systems, as well as individuals seeking insights into the practical challenges of working with magnetrons.
Locrian
I'm in the process of refurbishing a 915mhz 30kw Microwave power supply. The problem I'm having is that the electromagnet coil's water tubing is busted, and so we are having to replace it, and the standard replacement part is somewhat expensive ($2000+) and will take weeks to arrive. I've found a local shop that specializes in electromagnets and say they can duplicate my old one for less money and quicker return.
Anyways, it's the theory I'm interested in.
There are lots of salespeople in this industry, and a few people who know details about magnetrons, but I'm not finding anyone who can tell me how specific the magnet has to be. Obviously I hope wherever I get a replacement it will be the same as the original, but I want to have my bases covered if the magnetic field produced by the replacement is off by a few %.
So does anyone have any information and/or thoughts about how the magnet affects the magnetron? I understand the theory, but knowing how it will react in practice is a very different thing...
I've talked to a lot of people at many different companies and a couple of universities about this.
It's a simple question, that I haven't found an answer to.
I've come to the conclusion that all the physicists who understand magnetrons have long died, and all we're left with are a compliment of EE who know how to wire them up, and a mass of drooling salespeople determined to hock you another one.
I will venture a guess.
It doesn't seem as though the magnet is a very critical component. For one thing, they seem to be using simple permanent magnets in microwave ovens. For the frequency output, it seems like the resonant cavities within the anodes vanes are the most important feature. For the power output, it seems like the anode voltage (the potential difference between anode and cathode) is the most important feature. As far as I can tell, the magnet just needs to be strong enough to significantly circulate the electron beam.
Keep in mind that I know almost nothing about magnetrons. In fact, I hadn't heard of them until I read your post, so I am posing wild conjecture based on some brief internet research. I am rather surprised that someone is trying to charge you $2,000 for a cooling system.
Appreciate it turin! I agree with your advice and my company is going to have one wound for us instead of buying the one from the company that made the original. We recently grabbed an osciloscope and determined it's inductance (with a little help from a sophmore physics lab sheet that my parter used to teach :wink: ) and are going to have a local specialty place wind us a new one. That's the trick; the cooling coil isn't separable from the magnet so if you bust your coil you have to replace the whole thing.
If something melts down and a 12kV 50 amp arc decimates our labspace I'll let you know, if I'm around to do it!
I never worked on a magnetron, but I did work on an orotron. The most important factor was field continuity, not the exact field strength. The condition of the pole pieces was the most significant factor in field continuity. Can you remove the pole pieces before shipping out the magnet? This assumes you'll be more careful removing and replacing them than the repairman though!
Njorl
  • · Replies 37 ·
30K
