Need help on a problem F=ma and i have gravity
  • Thread starter Thread starter wash
    F=ma Gravity
The discussion revolves around a physics problem involving force, mass, and acceleration, specifically in the context of an object falling under the influence of gravity. The original poster presents values for mass and acceleration, questioning the force of a collision.
  • Exploratory, Assumption checking
  • Participants explore the relationship between force, mass, and acceleration, questioning the validity of the acceleration value provided. Some participants suggest that the acceleration due to gravity is incorrectly stated, while others consider the implications of the given values on the scenario described.
The discussion is ongoing, with participants providing hints and questioning assumptions without reaching a consensus. There is an indication that further clarification of the problem's wording may be necessary for a more productive discussion.
There is a suggestion that the acceleration value may not correspond to typical gravitational acceleration, indicating a potential misunderstanding or miscommunication regarding the problem's setup.
wash
F=?
m=295kg
a=75m/s^2
an object is falling with a mass 295kg and has an acceleration of 75m/s^2 what is the force of the collision.
F=295(75 * or + gravity)
You've got the wrong idea about how to solve the problem.
Hey Ernest, help him/her out, and in doing so help me out. I'm curious how that would be figured.
FYI... Haven't yet gotten beyond algebra..
I'm sorry, I can't. It's homework. But I will give you a hint. The rate to which gravity accelerates falling objects is not 75 m/s2. If the problem has been correctly copied, then that hint should help
Assuming that the acceleration figure is correct, which implies that the object is falling somewhere with a much higher gravitational attraction, the weight of the object is given by F = ma = 295kg *75 m/s^2 = 22,125 Nt.
The wording suggests that what might really be asked for is the energy of the collision, or E = (1/2)mv^2.
wash, can you post the exact wording of the problem?
  • · Replies 24 ·
  • · Replies 21 ·
  • · Replies 18 ·
