Proving Unique Solution for ab = ba Using Logarithms | Homework Equations
  • Thread starter Thread starter songoku
    Logarithm Proof
The problem involves positive integers a and b, where a < b, that satisfy the equation ab = ba. The original poster attempts to prove the uniqueness of the solution using logarithms and is seeking guidance on the approach.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss taking logarithms of both sides of the equation and explore different bases for the logarithms. There are attempts to manipulate the equations derived from logarithmic identities, but some participants express confusion about the steps and assumptions made.
There is ongoing exploration of the problem with various approaches being suggested. Some participants have raised questions about the validity of certain steps and assumptions, particularly regarding the behavior of logarithmic and exponential functions. No consensus has been reached, and the discussion remains open with multiple interpretations being explored.
Participants note that a and b are positive integers, and there is a contradiction arising from the assumption that a < b. The discussion includes confusion about the implications of logarithmic properties and the conditions under which the equations hold true.
songoku
Positive integers a and b, where a < b, satisfy the equation :
ab = ba
By first taking logarithms, show that there is only one value of a and b that satisfies the equation and find the value !
logarithm
I know the solution just by guessing, a = 2 and b = 4 but I don't know how to do it...
[tex]a^b=b^a[/tex]
[tex]b*log~a=a*log~b[/tex]
Then I stuck...:frown:
Thanks
try taking logs to base a or b instead of base 10
Hi rock.freak667
I think it will be the same.
[tex]a^b=b^a[/tex]
[tex]b*\log_{a}~a=a*\log_{a}b[/tex]
[tex]b=a*\log_{a}b[/tex]
Then stuck again...:(
Thanks
Think of only one variable at a time (e.g. b in the last equation of your previous post).
Since a and b are positive integer,
we can conclude a,b>0 without generalisation.
First by taking log base a,
[tex] <br /> b=a log_{a}b[/tex]
[tex]b log_{b}a=a[/tex]
substituting to initial equation,
[tex]a^{2}-alog_{a}b=0[/tex]
[tex]a=0[/tex] or [tex]a=log_{a}b[/tex]
Therefore, [tex]a=log_{a}b[/tex]
is the only solution for a since logarithm curve is constantly decreasing.
[tex]b=a^{a}[/tex]
since exponent curve is ... leaving this part to you (=
Hi turin and icystrike
sorry I don't understand what you mean. From my last equation :
Then, think only b as variable. how to continue? what about a?
I don't understand this part. To which initial equation do you substitute?
[tex]b=a^{a}[/tex]
even though I can reach this part, I still don't know how to continue. I think logarithm curve is constantly increasing, not decreasing. From y = log x, the value of y will increase if x increases.
exponent curve is also constantly increasing, but from b=aa, how to deduce that a = 2?
Thanks a lot
I'm with Songoku on this; I'm not following what you are doing. I understand how you got both equations above, but your description is that you are taking the log base a of both sides of the original equation. In your second equation you're taking the log base b of both sides of the original equation.
Now this doesn't make any sense to me. Where did it come from? This is equivalent to a2 - b = 0 from the first of your two equations above, where you have b = a logab.
Assuming that the base is larger than 1, any log curve is constantly increasing. IOW, if x1 < x2, then logax1 < logax2.
icystrike said:
[tex]b=a^{a}[/tex]
Mark44 said:
Assuming that the base is larger than 1, ...
Whoops, I thought I knew how to do the problem, until you pointed out this assumption.
So unless icystrike can explain what he's done, we're back at square 1 on this problem.
Sorry guys I've made a mistake. we are back to square one.
Now I'm able to solve it.
But it contradicts the statement that a>b.
[tex] ((lg a)/(lg b))=((lg b)/(lg a))[/tex]
[tex](lg a)^{2}-(lg b)^{2}=0[/tex]
[tex](lg a-lg b)(lg a+lg b)=0[/tex]
Therefore a=b which contradicts a>b
Thus the only possibility is [tex]a=(1/b)[/tex]
since a is a interger,
b must divide 1,
whereby b=1
suggest a=1 .
and resulting a=b.
Which again leads to a contradiction
How do you get the equation above? We know that ab = ba, so b loga = a logb
==> b/a = (log b)/(log a)
How do you get from this equation to (log a)/(log b) = (log b)/(log a)?
b must divide 1,
whereby b=1
suggest a=1 .
and resulting a=b.
  • · Replies 22 ·
