Cell Stoichiometry: Mass of Na Deposited in 2h
The discussion revolves around calculating the mass of sodium deposited at the cathode of a molten NaCl electrolytic cell when a current of 10.0 A flows for 2.00 hours. The focus is on the stoichiometry of the electrochemical reactions involved and the application of Faraday's law of electrolysis.
  • Homework-related
  • Some participants suggest using the half-reaction Na+ + e- → Na for calculating the mass of sodium deposited.
  • Others inquire about the necessity of balancing the electron in the half-reaction, with some expressing confusion about when to balance.
  • One participant emphasizes that the sodium reduction reaction is already balanced and questions the need for further balancing.
  • Another participant mentions checking standard reduction potentials to confirm the reaction.
  • There is a discussion about the appropriate notation for states of matter in chemical equations, with differing opinions on the use of subscripts versus plain text.
  • Some participants clarify that for this specific calculation, only the sodium half-reaction is needed and that balancing for the overall reaction is not required.
Participants generally agree that the sodium reduction reaction is balanced as presented. However, there is disagreement regarding the necessity of balancing electrons for the specific calculation, with some participants advocating for it and others stating it is unnecessary.
Participants express uncertainty about the application of balancing in this context, particularly regarding the relevance of the overall reaction versus the half-reaction for sodium. There are also differing views on notation conventions in chemical equations.
Nope
Determine the mass of sodium deposited at the cathode of a molten NaCl(l) electrolytic cell if 10.0 A flow through the cell for 2.00h.
For the mole ratio,
Na+ +e --> Na
2Cl- --> Cl2 + 2e
Should I balance the electron ? 2Na+ +2e --> 2Na
or I use Na+ +e --> Na
Thanks
Na+ + e- -> Na will do.
Do you know Farady's law of electrolysis? Do you know how to calculate charge given current and time?
Yes.
But when should I balance the electron?
Not sure what you mean - sodium reduction reaction is written is already balanced.
methods
You balance the half equations, Then identify which is oxidised and reduced, then you add the electrons to the specific sides (RHS reduction, LHS oxidisation). but if Na+(aq) + e- --> Na(s).
Just check your standard reduction potentials chart and you'll see.
Na+(aq) + e- -> Na(s) - state of matter symbol should be listed in plain text, not subscript nor anything.
These are of no use here - you are already told what is the reaction that goes on - reduction of sodium.
methods
The super script was an accident, But I don't see why i cannot use sub script for them?
See http://www.iupac.org/reports/provisional/abstract05/GreenBook051206_prs.pdf , General Chemistry section, Other symbols and conventions in chemistry (2.10.1), (vi) States of aggregation.
methods
You don't have to - we are interested only in sodium and we need just sodium half reaction. Balanced - but half reaction only.
methods
13K
9K
