Find angular velocity from constant linear velocity
The discussion focuses on calculating the angular velocity of a rotating disk with a diameter of 2.50 meters, which is used to raise an elevator at a constant linear velocity of 25.0 m/s. The key equation used is v = r * omega, where v is linear velocity, r is the radius, and omega is angular velocity. To find the angular velocity in RPM, the circumference of the disk is calculated using the formula π * diameter, followed by determining the period of rotation and converting it to minutes. The final result provides the necessary revolutions per minute to achieve the desired linear speed.
  • Understanding of angular velocity and linear velocity concepts
  • Familiarity with the equation v = r * omega
  • Knowledge of rotational motion and its equations
  • Basic skills in unit conversion, particularly between seconds and minutes
  • Learn how to derive angular velocity from linear velocity using the formula v = r * omega
  • Study the relationship between linear and angular motion in rotational dynamics
  • Explore the concept of angular frequency and its applications in physics
  • Investigate the effects of tension and forces in systems involving pulleys and ropes
Students studying physics, particularly those focusing on rotational dynamics, engineers working on mechanical systems, and anyone involved in designing systems that involve pulleys and elevators.
dentulousfing
A rotating disk of 2.50m in diameter serves tu connect a counter weight to a mass through a massless rope. The rope does not slip on the disk so, there is no friction on the rim. What angular velocity in rpm must the disk turn to raise the elevator at 25.0 m/s?
v=r*omega
a(rad)=omega^2*r
I am confused here.
since the linear velocity of the rope is constant, its linear acceleration should be zero, and every point on the rope should have the same velocity. Becasue the radius of the rim is constant, the angular velocity should be zero and angular acceleration as well.
a(tan)=r*alpha
alpha=0
a(tan)=0
because the tangential acceleration is zero, then the acceleration vector should have a radial component only: a(rad)=omega^2*r
I could factor out omega from the equation and obtain:
omega=square root of a(rad)/r.. but I don't have the radial component of the acceleration...
should I just use the equation v=omega*r, and factor out omega from it?
Just wondering, if I were given the tension on the rope, caused by the weight of the mass connected to it, or a given displacement with this constant pulling force by the rope on the mass, would these factors just be ignored by the fact that the bofy is moving with a constant velocity, thus, a=0, and the net force on the object is zero as well?
please help
thanks
I believe that you should find the circumference of the wheel [ PI * diameter ].
Divide the circumference by the speed the lift is expected to travel (25 m/s); this will give you the period (time for one full rotation of the wheel) in seconds.
Work out the angular frequency by finding the reciprocal of the period [ 1 / period ], but to get your answer in RPM convert the period into minutes rather than seconds by dividing it by 60.
This should give you the answer expected in the question; the required revolutions per minute to raise/lower the lift at 25 m/s.
Please do correct me if I'm wrong, anyone.
  • · Replies 17 ·
  • · Replies 17 ·
18K
  • · Replies 32 ·
  • · Replies 42 ·
