A football being kicked through air
  • Thread starter Thread starter Chandasouk
    Air
The discussion centers on the physics of a football's motion during a field goal kick, specifically analyzing the work-energy principle. The false statement identified is D, which claims that the kicker did not perform work on the ball before it left his foot. The participants confirm that the work done by the kicker results in kinetic energy, which contradicts statement A, as the ball retains kinetic energy at the peak of its trajectory. The total mechanical energy of the ball-Earth system remains constant, affirming statement C as true.
  • Understanding of Newton's laws of motion
  • Familiarity with the work-energy theorem
  • Knowledge of kinetic and potential energy concepts
  • Basic principles of projectile motion
  • Study the work-energy theorem in detail
  • Explore the principles of projectile motion in physics
  • Learn about energy conservation in mechanical systems
  • Investigate the effects of air resistance on projectile motion
Physics students, educators, and anyone interested in understanding the dynamics of motion and energy transfer in sports contexts.
Chandasouk
The sentences below might be used to describe the motion of the football as it went through the air during the field goal kicked in the last seconds of the RU vs Louisville game. If you neglect air resistance, which of the following is FALSE?
a)
The work done by the kicker on the ball was converted entirely to gravitational potential energy of the ball at the top of its path.
b)
The ball had its lowest speed at the top of its path.
c)
The total mechanical energy of the ball-Earth system didn’t change after the ball left the kicker’s foot.
d)
The kicker did work on the ball before it left his foot.
I said D was the false statement.
Since the ball was kicked, its a parabolic motion so at the top of it's path, the velocity is zero so B is true. The energy you started with initially is the amount you always ends up with, so C is true.
I was stuck between A and D. I think D is false since Work is FD, so it's possible he can apply a force on the ball before it leaves his foot, but it needs to travel a distance to be considered work?
Letter A on the other hand, I'm not sure if the energy is completely converted to potential at the highest point. The ball still has a velocity in it's horizontal component so would've it have KE as well at the highest point?
It's true that no work is done on something that isn't moving, but that doesn't apply to the football. The kicker's foot stays with the football for a short time while the football begins to move, and that's how the work is done on it. (If you think about it, the ball definitely gains some kinetic energy, and there's no way that could happen without some work being done)
Sounds reasonable to me...
Thanks for the clarification, i guess sometimes a little common sense is needed :-p
15K
