A ball kicked from the ground (Projectile Motion)
The discussion focuses on calculating the speed of a ball kicked at an angle of 65° with an initial speed of 8 m/s when it reaches half of its maximum height. Participants utilized trigonometric functions to determine the horizontal and vertical components of velocity, yielding 7.25 m/s and 3.38 m/s, respectively. The conservation of energy principle was applied to derive the final speed at half the maximum height, leading to a calculated speed of 6.14 m/s. Corrections were suggested regarding the maximum height calculation, emphasizing the need for accurate application of kinematic equations.
  • Understanding of projectile motion principles
  • Knowledge of trigonometric functions for component resolution
  • Familiarity with kinematic equations
  • Basic concepts of conservation of energy
  • Study kinematic equations for projectile motion in detail
  • Learn about energy conservation in mechanical systems
  • Explore the effects of air resistance on projectile motion
  • Practice problems involving vector resolution in physics
Students studying physics, educators teaching projectile motion concepts, and anyone interested in applying kinematic equations to real-world scenarios.
Chandasouk
A ball is kicked from the ground at an angle of 65° and at a speed of 8 m/s. What is its speed when it reaches 1/2 of the maximum height along the path, assuming that air resistance is negligible?
My head hurts from this.
I made a diagram of this event by using a vector pointing diagonally with 65 degrees to the horizontal
I used trig to find the velocity at the x and y components
sin65 = y/8
Y = 7.25m/s
cos65=x/8
x = 3.38m/s
from here, i didn't know what to do. I used the equation V^2 = Vi^2+2a[tex]\Delta[/tex]x
[tex]\Delta[/tex]x = .58287751m
Then, to obtain the height
tang65=H/.58287751m
H = 1.25m
then half of that is .6249m
and uh...conservation of energy
Intial 1/2mVi^2 = Final mgh + 1/2mVf^2
You can cancel out the m's
1/2(8)^2 = (9.80)(.6249m) + .2Vf^2
Vf= 7.19 = 7.2m/s ?
Your horizontal and vertical components are correct.
Your max height is not.
Recommend you make two headings and write the appropriate equations:
Horizontal: constant speed so
d = vt
Vertical: accelerated so
V = Vi + at, d = Vi*t + .5at^2
At maximum height, V = 0. Put that and your known values for the vertical Vi and acceleration into the first equation and solve for time of max height.
Put that time into the second equation to find the maximum height.
d = vt
0 = 7.25ms+(-9.80m/s^2)t
-7.25m/s = -9.80m/s^2t
t=.74 seconds
d = (7.25)(.74) + .5(-9.80)(.74)^2
D=2.68m and half of that is 1.34m
then conservation of energy
1/2(8)^2 = (9.80)(1.34m) + 1/2Vf^2
Vf = 6.14m/s ?
  • · Replies 21 ·
  • · Replies 18 ·
