What is the domain of the given function when expressed in terms of x and y?
  • Thread starter Thread starter soopo
    Domain Function
The discussion revolves around determining the domain of a function defined in terms of two variables, x and y. The function includes a square root and an infinite series, prompting participants to explore the conditions under which the function is defined.
  • Exploratory, Assumption checking
  • Participants discuss the initial assumption that the domain might be restricted to x > 0 and y > 0 based on the square root terms. However, they question whether the convergence of the infinite series also affects the domain.
There is an ongoing exploration of the conditions for convergence of the series, with some participants suggesting that the domain may be limited to a specific region around the origin. Multiple interpretations of the domain are being considered, particularly in relation to the behavior of the series.
Participants note the importance of considering the convergence of the series when determining the domain, indicating that the problem may involve more complexity than initially assumed.
soopo
What is the domain of the following function?
[tex]f(x,y) = (\sqrt(x) + x\sqrt(y)) \sum_{k=1}^{\infinity} (k^3 + k) x^k y^k[/tex]
when [itex]D_f \subset \Re^2[/itex].
The domain is [itex]x>0 \in \Re[/itex] and [itex]y>0 \in \Re[/itex] in my opinion.
If f(x, y) were defined only as [itex]\sqrt{x} + x\sqrt{y}[/itex], that would be correct. However, I think you need to take the summation into account, and determine for which x and y the series converges.
The summation is to infinity.
The sum is always positive so the range is always real.
This would suggests me that x > 0 and y > 0.
However, I am uncertain, since the solution should not be that easy.
The sum is probably convergent only for x and y in some disk centered at the origin. Outside that disk the sum would be divergent, hence the function would be undefined. It really seems to me that if you want to find the domain for this function, you need to see which values of x and y are such that the series converges.
  • · Replies 23 ·
