Uniform Convergence: Find Domain of Intervals (a,b)
The series f(x) = ∑ (1/(n(1+nx²))) converges uniformly on intervals of the form (a,b) where a > 0.5. Utilizing the Weierstrass M-test, the series can be bounded by M_r = 2/r² for x > 0.5, confirming uniform convergence. For any interval (a,b) where a ≤ 0.5, the series fails to converge uniformly. The critical point for non-convergence is at x = 0, where the series does not converge.
  • Understanding of uniform convergence in series
  • Familiarity with the Weierstrass M-test
  • Knowledge of series convergence criteria
  • Basic calculus, particularly limits and bounds
  • Study the Weierstrass M-test in detail
  • Explore examples of uniform convergence in series
  • Investigate the implications of convergence at boundary points
  • Learn about different convergence tests for series
Mathematics students, particularly those studying real analysis, and educators looking to deepen their understanding of series convergence and uniform convergence criteria.
kidsmoker
Consider
[tex]f(x)=\sum\frac{1}{n(1+nx^{2})}[/tex]
from n=1 to n=infinity.
On what intervals of the form (a,b) does the series converge uniformly? On what intervals of the form (a,b) does the series fail to converge uniformly?
Weierstrass M-test: If there exists numbers [tex]M_{r}[/tex] for each [tex]f_{r}(x)[/tex] such that [tex]f_{r}(x) \leq M_{r}[/tex] and
[tex]\sum M_{r}[/tex]
converges, then [tex]\sum f_{r}[/tex] converges uniformly.
Write
[tex]f_{r}(x)=\frac{1}{r(1+rx^{2})}[/tex] .
If i just consider the case where x>1 then
[tex]\frac{1}{r(1+rx^{2})} \leq \frac{1}{r^{2}x^{2}} \leq \frac{1}{r^{2}}[/tex]
so let
[tex]M_{r}=\frac{1}{r^{2}}[/tex]
and the sum of this from r=1 to r=infinity converges. So
converges uniformly for x>1? Or am I misunderstanding the M-test?
But then say I went with x>0.5 instead of x>1. I could then choose
[tex]M_{r}=\frac{2}{r^{2}}[/tex]
to get uniform convergence for x>0.5? etc etc
So what's the required domain? I'm really confused :-(
That's exactly correct if you just use M = 4/r^2 instead. How about uniform convergence for x>a where a is an arbitrary positive real number? You can generalise your answer easily. Then there's only one real number you're leaving out, and it turns out that the series does not converge there.
  • · Replies 24 ·
  • · Replies 21 ·
