Register to reply
A mass on a spring, trying to find dispacement after at certain time. (Please Help )
by The Merf
Tags: oscillation, spring, suspended mass
Share this thread:
The Merf
#1
Nov16-09, 10:42 AM
P: 10
A 0.27 kg mass is suspended on a spring that stretches a distance of 4.9 cm. The mass is then pulled down an additional distance of 12.5 cm and released. What's the displacement from the equilibrium position with the mass attached (in cm) after 0.42 s? Take up to be positive and use g = 9.81 m/s^2
m=.27kg
t=.42s
g=9.81m/s^2
I don't know how to represent it, but I believe that 4.9 is the equilibrium.
12.5cm is the initial displacement (maybe x0?)
2. Relevant equations
I have no idea, this is what I need help with.
maybe u=1/2kx^2, but I don't have a k, and I don't need u, but it is the only spring equation I know
3. The attempt at a solution
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
The Merf
#2
Nov16-09, 10:53 AM
P: 10
I also found the fallowing equations dealing with harmonic oscillation:
[tex]
x(t)=A\sin(\omega t)+B\cos(\omega t)
[/tex]
[tex]
\omega^2 =\frac{k}{m}
[/tex]
i'm not sure what the w is
The Merf
#3
Nov16-09, 10:55 AM
P: 10
ooh, and this one look very promissing:
[ctex]
x(t)=\frac{v_0}{\omega}\sin(\omega t)+x_0\cos(\omega t)\;.
[/ctex]
I know that v0 is 0 so that wipes out the first half, I think x0 is 12.5, but where does the 4.9 come in and what is the w?
hmm, the image doesn't seem to work so i'm going to try writing it out:
x(t)=((v0)/w)sin(wt) + (x0)cos(wt)
rl.bhat
#4
Nov16-09, 11:06 AM
HW Helper
P: 4,433
The stretching force is mg = -kx. Find k.
When you stretch the spring further and release, it will execute a simple harmonic motion with amplitude A and angular frequency ω =sqrt(k/m)
Can you write the equation of SHM and find x at a given time?
Register to reply
Related Discussions
How to find net force using mass, distance, and time? Introductory Physics Homework 2
Mass-Spring-Damper time response to step input Introductory Physics Homework 0
Spring constant with given mass, find Work... Introductory Physics Homework 2
Find the ratio of mass spring, oscillation problem Introductory Physics Homework 9
Accelleration and dispacement of planes and babiess Precalculus Mathematics Homework 3
