Find all solutions of the equation 3sin^2x-7sinx+2=0
  • Thread starter Thread starter tennistudof09
The discussion revolves around solving the equation 3sin²x - 7sinx + 2 = 0 within the interval [0, 2π). Participants are exploring the solutions for sin(x) based on factored forms and the properties of the sine function.
  • Mixed
  • The original poster attempts to factor the equation and solve for sin(x) but encounters difficulties in determining the angles corresponding to sin(x) = 1/3 and sin(x) = -2. Other participants question the correctness of the factorization and the implications of the sine function's range.
Participants are actively discussing the factorization of the equation and the implications of the sine values derived. Some guidance is provided regarding the correct interpretation of sine values, particularly noting that sin(x) cannot equal -2 and questioning the validity of certain calculations. There is no explicit consensus on the correct approach yet, but multiple interpretations are being explored.
There is a noted confusion regarding the factorization of the equation and the values of sine, particularly with respect to the range of the sine function. Participants are also reflecting on the implications of their calculations and the need for corrections.
tennistudof09
Find all solutions of the equation 3sin^2x-7sinx+2=0 in the interval [0,2pi).
I factored it out first and got (3sinx-1)(sinx+2)=0 and then solved, and got sinx=1/3 and sinx=-2 if I did it correctly. What i am having trouble with is finding where sin(x)=1/3 and -2.
One of your factors is incorrect.
In your interval [0, 2pi) there are two solutions to sin x = 1/3. Your calculator will give you one of them, and you'll need an identity to figure out the other one.
To solve sin x = - 2 (which is incorrect for this problem), first think about the range of the sine function.
You factored incorrectly. That should be (3sinx-1)(sinx-2)=0
So sin x = 1/3 and 2
Take the sine inverse of the two.
Sin x = 2. csc 30 = 2 so sin- (1/2) = x. x=30 degrees or pi/6 rad.
sin x = 1/3. sin- (1/3)=x. x=19.47 degrees or .34pi.
That's what I would've done but I'm not sure if that was correct or not, so don't base your work on my steps.
If it were correct, one should be able to find the solutions to the equation from there. Recall that sine is only positive in quadrant 1 and 2.
So are you saying here that sin(30 deg.) = 2?
The measure of the angle is not .34 pi. That would be a little over 1 radian, which is way bigger than 19+ degrees.
Sorry, I didn't mean .34 pi. I just meant .34 rad.
And as for the sin(30) = 2, likely no. That's why I said to him to not base his work on my steps. I was hoping someone would correct it and I'd learn something new. I just recall something about cot x = a. tan x = (1/a) x = tan- (1/a). I guess that's where I derived it from but yes, it would still be incorrect and that is why I said what I said. But come to think of it, that wouldn't be possible as the opposite side can not be longer than the hypotenuse.
  • · Replies 24 ·
