A bead on a spinning rod with magnetic field
The problem involves a bead of mass m and charge q placed on a frictionless, rigid rod that spins about one end at a constant rate w in the xy plane, with a constant magnetic field B = B_0\hat{z}. The task is to write the Lagrangian for the system using the generalized coordinate r, which represents the distance of the bead from the origin.
  • Mixed
  • Participants discuss the choice of coordinates and the expression for velocity, questioning the treatment of radial and tangential components. There is exploration of the vector potential and its implications for the Lagrangian. Some participants express uncertainty about the inclusion of terms related to radial velocity and the correct form of the Lagrangian.
There is an ongoing exploration of the Lagrangian formulation, with participants providing feedback on each other's expressions and calculations. Some guidance has been offered regarding the treatment of velocity components and the implications for the Lagrangian, but no consensus has been reached on the final form of the equations of motion.
Participants are working under the assumption that the bead can slide along the rod, which affects the velocity calculations. There is also a focus on ensuring that all terms in the Lagrangian are accounted for, particularly those arising from the magnetic field's influence on the bead's motion.
Loxias
A bead of mass m and charge q is placed on a frictionless, rigid rod that is spun
about at one end at a constant rate w on the xy plane. There is a constant magnetic
field in space [tex]B = B_0\hat{z}[/tex]
Write the Lagrangian for the system, use the generalized coordinate r (the
distance of the bead from the origin).
I chose
[tex] x = rcos(wt) ,<br /> y = rsin(wt)[/tex]
and from
[tex]v = rw[/tex]
we get
[tex]v = (wrcos(wt), wrsin(wt))[/tex]
assuming vector potential
[tex]\vec{A} = B_0(0,x,0)[/tex]
and [tex]L = \frac{1}{2}m V^2 + qV\vec{A}[/tex]
I get
[tex]L = qB_0wr^2cos(wt)sin(wt) + \frac{1}{2}m (\dot{r}^2 +r^2w^2)[/tex]
deriving equations of motion:
[tex]m\ddot{r} = mrw^2 + 2rB_0qwcos(wt)sin(wt)[/tex]
which is good unit-wise.
My question is, did I derive everything right or did I forget something or misused the potential of magnetic field?
Hi Loxias, welcome to PF!:smile:
Is the pivot end of the rod held fixed at the origin, or is it allowed to move?
Thanks :smile:
It is fixed.
Loxias said:
I chose
Good...
and from
[tex]v = rw[/tex]
we get
But [itex]v\neq r\omega[/itex]...[itex]\textbf{v}=\frac{d\textbf{r}}{dt}[/itex] and if the bead is allowed to slide along the rod , [itex]r[/itex] will dpend on time and you will need to use the product rule to calculate [itex]\textbf{v}[/itex]
good...
I assume you mean [itex]L=\frac{1}{2}mv^2+q\textbf{v}\cdot\textbf{A}[/itex] ?
I get
Where is the [itex]\sin(\omega t)[/itex] coming from, and shouldn't there be another term involving [itex]\dot{r}[/itex]? (from the [itex]q\textbf{v}\cdot\textbf{A}[/itex] part)
The bead is allowed to slide.
It seems i have forgotten about the radial velocity, but [tex]v = wr[/tex] is the one tangent to it.
so should the speed be [tex](\dot{r}, rw)[/tex] or am I still wrong?
you assume right about the lagrangian.
The [tex]sin(wt)[/tex] came from the velocity i chose earlier, and i don't have [tex]\dot{r}[/tex] because i forgot about the radial velocity.
so to sum up, the right this is [tex]L = \frac{1}{2}mv^2 + q(\dot{r},wr,0)(0,rcos(wt),0)[/tex]
because if it is, i will still get the same result as earlier and it the radial velocity doesn't affect [tex]L[/tex] (though i think it should since its in a right angle to the field)
Thanks again
It depends by what you mean by [itex](\dot{r}, r\omega)[/itex]...do you mean [itex]\textbf{v}=\dot{r}\hat{\mathbf{e}}_r+r\omeg\hat{\mathbf{e}}_{\theta}[/tex] or [itex]\textbf{v}=\dot{r}\hat{\mathbf{e}}_x+r\omega\hat{\mathbf{e}}_y[/tex]?[/itex][/itex]
[tex]\textbf{v}=\dot{r}\hat{\mathbf{e}}_r+r\omega\hat{\mathbf{e}}_{\theta}[/tex]
Okay, so hat do you get for [itex]\textbf{v}\cdot\textbf{A}[/itex] then?
Ok ok, I first thought i should work in spherical coordinates and then I should obviously transform [tex]A[/tex] to those coordinates as well, but I've had a lot of trouble with that.
Then, why not use cylindrical coordinates?
In that case, I found transformation equations and I get
[tex]A = (rcos(wt)sin(wt), rcos^2(wt), 0)[/tex]
[tex]v = (\dot{r}, wr, 0)[/tex]
and the product is straightforward.
the transformation equations :
[tex]A_{\rho}\,=\,\hat{\rho}\,\cdot\,\overrightarrow{A} \,=\,A_x\,cos\,\phi\,+\,A_y\,sin\,\phi[/tex]
[tex]A_{\phi}\,=\,\hat{\phi}\,\cdot\,\overrightarrow{A} \,=\,-A_x\,sin\,\phi\,+\,A_y\,cos\,\phi[/tex]
[tex]A_z\,=\,A_z[/tex]
following my previous post, I've just noticed something else and it might be where you were going for from the beginning :
[tex]v = (\dot{x}, \dot{y},0) = (\dot{r}cos(wt) - rwsin(wt), \dot{r}sin(wt) + rwcos(wt),0)[/tex]
and then
[tex]Av = (0,rcos(wt),0)(\dot{r}cos(wt) - rwsin(wt), \dot{r}sin(wt) + rwcos(wt),0)[/tex]
which will give the same result as the previous post.
Is that what you meant earlier?
and then
That looks better...what does that give you for your Lagrangian?
[tex]L = \frac{1}{2}m(\dot{r}^2+r^2w^2) + qB_0(r\dot{r}cos(wt)sin(wt) + r^2wcos^2(wt)[/tex]
which results in
[tex]m\ddot{r} = mrw^2 + qB_0rw + 2qB_0rwcos(2wt)[/tex]
Good...
which results in
That looks a little off to me...why not show me what you get for your derivatives?
[tex]\frac{\partial L}{\partial r} = mrw^2 + qB_0\dot{r}cos(wt)sin(wt) + 2qB_0rwcos^2(wt)[/tex]
[tex]\frac{\partial L }{\partial \dot{r}} = m\dot{r} + qB_0rwcos(wt)sin(wt)[/tex]
[tex]\frac{d}{dt} \frac{\partial L }{\partial \dot{r}} = m\ddot{r} + qB_0\dot{r}cos(wt)sin(wt) - qB_0rwcos^2(wt) +qB_0rwsin^2(wt) = m\ddot{r} + qB_0\dot{r}cos(wt)sin(wt) - qB_0rwcos(2wt)[/tex]
which results in
[tex]m\ddot{r} = mrw^2 + qB_0rwcos(2wt) + 2qB_0rwcos^2(wt)[/tex]
and from
[tex]cos(2wt) = 1-2sin^2(wt)[/tex]
you get my final answer
Good...
Looks like you got your signs backwards; [itex]\frac{d}{dt}\sin(\omega t)=+\omega\cos(\omega t)[/tex]<br /> and [itex]\frac{d}{dt}\cos(\omega t)=-\omega\sin(\omega t)[/tex][/itex][/itex]
:mad:
making it
[tex]m\ddot{r} = mrw^2 + qB_0rw[/tex]
seems good?
Looks good to me...you can check that you get the same thing from the Lorentz force law (just look at the radial component of the force, as there will of course be an azimuthal pseudo-force that keep the particle attached to the spinning rod)
Thanks for all the help :smile:
I am now trying to solve the equation of motion
[tex]\ddot{r} - Cr = 0[/tex] where [tex]C = \frac{mw^2+qB_0w}{m}[/tex]
solving this will give
[tex]r = C_1 e^{\sqrt{C}t} + C_2e^{-\sqrt{C}t}[/tex]
then i should make [tex]C_2 = 0[/tex], right? :shy:
  • · Replies 17 ·
