Thread Closed
Gravity/Planetary Forces Question - High School physics question
Share Thread Thread Tools
Nov16-09, 08:29 PM   #1
Find the distance an object needs to be in between the sun and the earth for it to be perfectly balanced (not moving)
2. Relevant equations
mass of earth = 5.98e24 kg
mass of sun=1.991e30 kg
distance between sun and earth = 1.479e11 m
Fg=Gm1m2/rē
3. The attempt at a solution
well, i tried making the Fg zero for two equations - one with Fg of the object to the sun, and one with Fg of the object to the earth..but it got messed up..can someone help me?
can i sub in the mass of the object as 1kg?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Nov16-09, 08:33 PM   #2
Mentor
Hint: The point at which the object won't accelerate is the point at which the gravitational forces on the object are *equal* in magnitude (and opposite in direction).
No, you don't need to substitute in a numerical value for the mass of the object, because it should cancel from both sides of the equation (meaning that the point at which the forces balance doesn't depend upon how heavy the object is).
Nov16-09, 08:37 PM   #3
so, do i put
Fg=(6.67e-11 x 5.97e24)/dē
Fg=(6.67e-11kg x 1.991e30kg)/1.479e11m-dē <---because d is the distance to the object, and 1.479e11 is the distance from sun to earth (?)
Nov16-09, 08:38 PM   #4
oh, and then cram the equations together :P
Nov16-09, 09:02 PM   #5
Mentor
closertolost
When I hinted that the gravitational forces on the object due to Earth and the sun were equal, I meant for you to actually *equate* them. So, using the subscripts E and S for Earth and sun respectively, we have:
FE = FS
GmME/r2 = GmMS/(R-r)2
You'll notice I've done something interesting here with the distances. I've decided to call the distance between the Earth and the sun "R." So, if the object is a distance r from Earth, then its distance from the sun must necessarily be R-r (since the problem states that the object lies along a straight line connecting the two celestial bodies). If you're still not sure, draw a diagram. EDIT: I see that you already figured this out, nice work.
You'll also notice that m, the mass of the "test object" cancels from both sides of the equation, and so does the gravitational constant, G. This leaves you with an equation for r (the thing you are trying to calculate) in terms of three known quantities. The three known quantities are the masses of the Earth and sun, and the Earth-sun distance, R.
Nov16-09, 09:04 PM   #6
ahah thanks very much! i have it now :)
Thread Closed
Thread Tools
Similar Threads for: Gravity/Planetary Forces Question - High School physics question
Thread Forum Replies
High school physics... basic question about two dimensional motion (WITH PICTURE) Introductory Physics Homework 2
Acceleration Question for a High School Physics Lab Introductory Physics Homework 1
Question About Physics Homework (High School Physics) Introductory Physics Homework 9
High School Physics Question Introductory Physics Homework 4
High School Physics Question! Introductory Physics Homework 13
