Saint
- 438
Can you help explain what are they?
Which one is better?
The discussion revolves around the comparison between RAID (Redundant Array of Inexpensive Disks) and SATA (Serial ATA), focusing on their definitions, functionalities, and implications for storage solutions. Participants explore various RAID configurations, their redundancy features, and the role of SATA as a data transfer standard.
Participants express differing views on the comparison between RAID and SATA, with some asserting that they serve different purposes and cannot be directly compared. There is no consensus on whether disk speeds need to match in RAID setups, and opinions vary on the implications of using drives of different sizes.
Some participants highlight limitations in their understanding of RAID and SATA, indicating that their knowledge may not cover all aspects of the topic. There are also unresolved questions regarding the specifics of RAID configurations and performance considerations.
This discussion may be of interest to individuals exploring storage solutions, particularly those considering RAID configurations and the implications of using SATA technology.
Correction, RAID-0 is a striped array and RAID-1 mirrored. And relatively speaking RAID-0 isn't really true RAID since there is no mirroring, meaning no redundancy.Anttech said:RAID = redundant array of inexpensive disks...RAID has different configs
(ie RAID0 = mirrored, RAID1 = Stiped, RAID5 = stiped with parity)
SATA = serial ATA a means of access a HD... old ATA standard as dduardo says...
You cannot compare RAID and SATA as you could have a 2 SATA HD with a software RAID running...
RAID is a way to make your HD's more redundant and SATA is a standard for access (if you may) your HD... Like comparing apples and pears
Artman said:You need a RAID controller, either on your motherboard or a card, you need multiple Hard drives of the same size and speed
Anttech said:Actually this is not 100% true, you do not need hardware to do RAID, you can do software RAID (Windows 2k/2k3 Server does this out of the box) the Disks do not have to be the same size. If you want to mirror disks, the disk that you are mirroring to need to be at least the same size as the master disk but can be bigger. Same as stripping I beileve.
