| Thread Closed |
Potential-energy function of diatomic molecule |
Share Thread | Thread Tools |
| Nov19-09, 01:08 AM | #1 |
Hi there all, I have this problem which I have issues with; theres some stuff I need to do in C and any help would be much appreciated.
![]() For V(o) = 36 i need to find the ground state energy and normalised ground state function using matrix methods. I am allowed to use Matlab to find the eigenvalues and vectors. The matrix method includes numerical techniques where theres finite approximations. ![]() This picture is a general solution; for this specific problem the potential V(i) = V(x(i)) and lambda is equal to E. Through finite approximations using Taylors rule you get the matrix ![]() Im guessing that the ground state energy is the eigenvalue for when phi(0) = 0 and the other eigenvalue will be when phi(L) = 0. Im guessing that the normalised ground state function would be the eigenvector of this matrix? So through the theory of eigenvalue and eigenvectors, deltaxsquared*lambda will be an eigenvalue and the matrix phi(1) phi(2) etc is an eigenvector. I effectively need to calculate the eigenvalues and eigenvectors of a symmetrix tridiagonal matrix... basically a Hermitian matrix and I am aware that the process for a Hermitian matrix is a lot simpler than for anti symmetric. NAG routines however are unfamiliar to me (they are meant to be used) I am allowed to use Matlab to calculate the eigenvalues and eigenvectors. I also need to write a C program to find the ground state energy and normalised ground state function using the matching method. I am completely unfamiliar with the matching method in C and I am not being given a lot of help. Apparently you have to start with 2 independant solutions, rescale one curve so that they cross and vary E until both curves have the same slope at the crossing point. I am aware however that this is very ambiguous so any help would be very appreciated. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Potential-energy function of diatomic molecule
| Rotation Spectrum of a diatomic molecule (QM) | Advanced Physics Homework | 1 | ||
| diatomic molecule | Introductory Physics Homework | 14 | ||
| QM perturbation theory: rigid diatomic molecule | Advanced Physics Homework | 5 | ||
| diatomic molecule problem | Advanced Physics Homework | 0 | ||
| diatomic molecule | Atomic, Solid State, Comp. Physics | 0 | ||
