What is the connection between frequency and particles in light?
  • Context: Graduate
  • Thread starter Thread starter zoobyshoe
    Frequency Light
The discussion explores the relationship between frequency and particles in light, particularly focusing on the nature of photons as particles and how frequency is understood in this context. Participants delve into quantum mechanics, wave-particle duality, and theoretical frameworks such as string theory, examining how these concepts relate to the behavior and properties of light.
  • Experimental/applied
  • Some participants argue that viewing light as particles leads to confusion regarding the concept of frequency, questioning whether individual photons possess their own frequency or if frequency relates to the number of photons passing a point over time.
  • Others propose that frequency is tied to the quantum mechanical phase of photons, with implications for energy and momentum, rather than the number of photons.
  • A participant mentions that in traditional quantum theory, each photon has a frequency that corresponds to its energy, distinguishing this from the intensity of light, which relates to the number of photons.
  • Some contributions discuss the analogy of wave bunches and Fourier transforms to visualize the relationship between frequency and photon properties, while acknowledging limitations in this model.
  • One participant speculates about the possibility of photons from a standard light source having a range of speeds, suggesting this could explain the appearance of white light and relate to redshift and blueshift phenomena.
  • Another participant raises questions about the implications of string theory on photon frequency and its relationship to string parameters.
  • There are references to experimental measurements of light speed at different frequencies, with some participants expressing skepticism about the uniformity of photon properties.
Participants express a mix of agreement and disagreement regarding the nature of frequency in relation to photons. While some clarify that frequency does not equate to the number of photons, others challenge or speculate on the implications of this understanding, indicating that multiple competing views remain in the discussion.
Limitations include unresolved assumptions about the nature of photons, the dependence on various theoretical frameworks, and the complexities of quantum mechanics that are not fully addressed in the discussion.
zoobyshoe
I am starting to slowly read QED, by Richard Feynman.
He is quite adamant that light is particles, and not waves, and he cites the evidence of the action of the device called the photomultiplier to explain his stance. I find this argument completely convincing.
However, looking at the photon as a particle causes me some confusion whenever he, or anyone, mentions the frequency of light.
Viewed as a particle, I have no idea whatever what is occurring at a given frequency to say that it even has a frequency.
Sometimes I wonder if this means that so many particles per unit time pass a given point. At other times I wonder if each individual photon possesses its own frequency in some regard: is it spinning at a certain number of spins per unit time, or is it, maybe, undulating somehow a certain number of times per unit time?
So, my question is "Does an individual photon have a frequency, and if so, what is it doing at that frequency?"
-Zooby
If you believe in string theory then a single photon will have frequency.but if you stick to classical physics you will will encounter the wave/particle duality.
this says that light has both wave and particle properties and many experiments have reinforced this especially youngs double slit.
regards
jamie
The frequency is defined as the change of quantum mechanical phase per unit time. That is to say, the quantum mechanical phase associated with the amplitude for the state, photon, electron, etc.. Analogously the wavenumber is the QM phase change per unit length. The are associated with the classical quantities energy and momentum, which combine to make a fourvector, the fourmomentum or fourwavenumber. The factor of conversion is h, Planck's constant.
It will get a good deal more interesting and complicated before you really begin to understand what it happening. The waves interfere with each other constructively and destructively in space and time, e.g. in the two slit experiment, producing effects which are not describable by classical mechanics.
In 'traditional' quantum theory, if you like, i.e. before De Broglie, Schroedinger and wavefunctions etc., each photon has a frequency, which manifests itself in the energy of each photon. If the light has a higher frequency, it means that each photon is more energetic, -not- that more photons pass per unit time. This (more photons passing) means that the light has greater intensity.
limited wave
In my book on early QM they used the classical description of a wave bunch to get the idea over . If you take several sinewaves and add them together( especially ones which have harmonic frequency reations) the effect is to produce a wave form with a modulated amplitude which looks like bunches of waves ( the bunches are repeated). They then go on to imagine an infinite set of sines with a limited bandwidth , the results are that you end up with one wave bunch of a given length and shape. This bunch has an average frequency related to the group chosen. The maths is based on the Fourier transform -- standard maths. This bunch however exhibits properties similar to the quantum mechanical concepts of property pairs momentum versus position etc and in fact can be used to deduce an approximation for h Planks constant. Although limited the model let's you ask questions such as -- how long is a photon-- it let's you picture more energy by showing how higher frequencies results in more waves in a bunch , it allows for self interference over some length range which let's you picture the double slit experiment ( however inaccurately).
I am not sure if this analogy is still used, QM has come a long way, but it does help envisage a particle ( localised) with wave properties and the maths is real.
Thanks everyone. These answers have been pretty helpful. I am clear now about the fact that the frequency of light has nothing to do with number of photons passing a given point per unit time, which is a good notion to be rid of, and that it does have to do with something the photon itself is doing at a certain frequency: changing its Quantum Mechanical Phase.
The rest will take me some time to mull over and sort out.
Thanks,
-Zooby
Not phase but energy and momentum. For a massless particle in relativity they are numberically equal. The frequency is the momentum divided by Planck's constant.
From your knowledge of bosonic string theory, does the string representing the photon operate in the curled up dimensions? It seems like maybe it only has to be in 4-d spacetime. Does the photon frequency (or momentum) directly relate to any string parameter?
Thanks in advance
Don
The oscillations of the string are what (are supposed to) generate the particles we experience. The string oscillates in all the transverse dimensions (that is the dimensions not internal to its world-sheet). This includes the compacted ones. There are exceptions where the string has its endpoints on two different branes and the branes are in various configurations.
yes but what if it is all wrong... i know i know... but what if all photons from a standard light source weren't identical... what if they had a range of speeds and the result of viewing tham all was a white light. i think that if we measured light for specific speeds we would find slow light and fast light. i don't have much of a reference for this idea but my own, but it fits, and explains a lot. especially when put to the test by the "red shift-blue shift" of a black hole.
I would imagine that someone has done this. Since the invention of the laser it is possible to have light all of one "color" i.e. frequency to test. I haven't heard of it, but I would be surprised if someone hadn't already checked to see if there is a different speed noticable for different specific colors.
It seems, too, pretty obvious from what has been pointed out in this this thread, that all photons are different from each other in many regards. (The single regard in which they aren't suspected of differing is the speed at which they all propagate.)
http://www.aip.org/enews/physnews/1999/split/pnu432-2.htm
[Exact citation: B. Schaefer, PRL v.82, p.4964 (1999).]
To date, that is the most accurate measurement of light of different freq. This means that we have no experimental evidence using the best technique we have so far of validating your "what if's".
Zz.
Addendum: This just came out. A new expt. measurement of the speed of light at extremely low freq., in the range of 5 to 50 Hz![1] Again, no detectable deviation, and based on the accuracy and limitations of the measurement, this puts the upper limit on any possible photon rest mass at less than 4 x 10^-52 kg (!). This number keeps getting smaller and smaller with each subsequent refinement and improved measurement.
[1] M. Fullekrug, PRL v.93, p.043901 (2004).
Adding Arrows
How, in practical terms, did Feynman figure out the beginning and ending direction of the stopwatch pointer? The concept is clear to me, but I don't see how anyone could accurately time a photon over such a short distance at such an enormously fast frequency. What is the trick to this?
I am familiar with Fizeau and MM, but it occurred to me that some different means of measuring the speed of light must be used for the very faint light from stars and events in far space. How do they gather such light, and measure its speed these days?
I also started reading QED a few days ago and I think you misunderstand what he was doing with the arrows. He wasn't measuring the speed of light, he already knew that. And since he also knew the distance, he could calculate the time. That's how he knew how far the clock hand would move.
Please correct me if I'm wrong, I'm just learning this stuff too.
OOPS, I meant to quote post#13.
I don't think the starting position of the clock is important as long as it's used for all arrows, it's the difference between arrows that gives the result.
Please. I KNOW he's not measuring the speed of light.
This is what I'm asking: how could he know the distance when a photon might take any possible path? Any photon that refelected and picked up by the photomultiplier may have reflected off the front or the rear surface. He implies that he is able to time the photons and derive the length of the path from the time.
Oh sorry, we must be reading different books.
All photons of length <15 nm to >9000 nm are particles
So, my question is "Does an individual photon have a frequency, and if so, what is it doing at that frequency?" -Zooby
The range noted in the title dwarfs the visible range of ~ 400 nm to 900 nm. It should be remembered that, for hundreds of years and long before the velocity of light was measured, spectral emissions were known only by
their lengths; only after "c" was known, was it possible to compute a pseudo-frequency: f = c/photon length. On the contrary, Faraday/Maxwell AC radio transmissions rightly have a reciprocal relation because they are truly electromagnetic waves.
Incidentally, although RPF's "QED" includes a 40-page Chap 2 (Photons: Particles of Light); the second chapter of Vol I of his lectures, page 2-5, shows that light is listed with the acknowleged wave phenomena of Radio Radar etc - of course it should have been listed with his particles group that included UV-, x- and gamma- particles (i.e., not rays). Cheers, Jim
NEOclassic said:
The range noted in the title dwarfs the visible range of ~ 400 nm to 900 nm. It should be remembered that, for hundreds of years and long before the velocity of light was measured, spectral emissions were known only by their lengths;
What do you mean by the term "spectral emission"?
What do you mean by "pseudo-frequency"? Are you saying the frequencies we ascribe to light are guesses or estimates, or are you saying the whole concept of light having a frequency is "pseudo"?
What do you mean by "Faraday/Maxwell AC radio transmissions"? (It's the "radio" part I'm wondering about. Obviously those two didn't work with radio.) And a reciprocal relation to what?
Yes the whole issue of EM waves vs photons(light) is one I was going to ask about specifically at some point. Maxwell, still aether-bound, asserted they were two related disturbances in the same medium, but not that they were exactly the same thing. Einstein, if I recall correctly, believed there was a kind of threshold beyond which EM became photons, but I don't know the details. They both arise in the electric field, but I'm wondering how clear anyone is about the cut off, or threshold, between the two. I have been under the impression that as low as infrared we already have photons.
At high frequencies waves act like classical particles(See for instance Physics of Waves by Elmore and Heald, in the section on Geometric Optics). There really isn't a cutoff, it just acts more and more like a particle. Waves already act exactly like quantum particles, so we do have photons with low frequency as well.
Thanks, jtolliver. This is a very interesting subject. Could you expand a bit on how waves already act exactly like quantum particles?
-Zooby
  • · Replies 29 ·
  • · Replies 0 ·
  • · Replies 21 ·
