Solving problem l'Hospital Rule
  • Thread starter Thread starter Slimsta
The discussion revolves around applying l'Hôpital's Rule to evaluate limits involving indeterminate forms, specifically focusing on expressions like \(\lim_{x\to \infty}(1+3x)^{1/x}\), \(\lim_{x\to 1}\frac{\ln x}{x^2+x-2}\), and \(\lim_{x\to \infty}\frac{x^2}{e^x}\). Participants explore the nuances of these limits and the conditions under which l'Hôpital's Rule can be applied.
  • Participants discuss the evaluation of limits and the identification of indeterminate forms. There are attempts to apply l'Hôpital's Rule and questions about the validity of certain steps, particularly regarding the limits that yield forms like \(\infty^0\) and \(\infty - \infty\). Some participants suggest taking logarithms to simplify expressions before applying the rule.
The conversation is ongoing, with some participants confirming the correctness of certain limits while others express confusion or seek clarification on specific steps. There is a mix of correct and incorrect interpretations of the limits, and guidance has been provided on how to approach the problems, particularly regarding the use of logarithms and the application of l'Hôpital's Rule.
Participants are navigating the complexities of limits that involve indeterminate forms and are encouraged to reconsider their approaches when faced with errors or misunderstandings. The discussion includes references to textbook examples and the need for careful application of mathematical rules.
Slimsta
solve
f(x)/g(x) = f'(x)/g'(x)
1. [tex]$\displaystyle \Large \lim _{x\to \infty }(1+3x)^{1/x}$[/tex] = 0
because 1+3x is infinity..
infinity^(1/infinity)
small#/big# = 0
so infinity^0 = 1
2. [tex]$\displaystyle \Large \lim _{x\to 1}\frac{\ln x}{x^2+x-2}$[/tex] = 1/3
(1/x) / (2x+1)...
3. [tex]$\displaystyle \Large \lim _{x\to \infty }\frac{x^2}{e^x}$[/tex] = infinity
cuz if plugging in infinity, i get infinity2/infinity = infinity
im i right so far?
1 and 3 are wrong, but 2 is right. The following are all indeterminate forms, which means that they aren't numbers, and the limits that are in these forms can come out to be anything.
[tex][\infty^0],~\left[\frac{0}{0}\right],~\left[\frac{\infty}{\infty}\right],~[\infty - \infty][/tex]
Use L'Hopital's Rule on #3, and you should see that the limit isn't infinite. #1 takes a fair amount of time to explain, so see if your textbook has an example that's similar. It involves taking logs before you use L'Hopital's Rule.
for #3.. if i plug in e^infinity it says error..
so it should be undefined right?
for #1
the rule states:
"If the expression
[tex] \frac{\lim_{x \rightarrow a} f(x)}{\lim_{x \rightarrow a} g(x)}[/tex]
has the form 0/0 or infinity/infinity, then l'Hôpital's rule states that
provided that that second limit exists."
what about
[tex] [\infty^0],~[\infty - \infty][/tex]
i know that for
[tex] [\infty - \infty][/tex]
it should be 1/x - 1/sinx or something like that
No, not for #3, and besides e^infinity is not a number. I don't know what you're plugging that into, but #3 has a limit. Use L'Hopital's Rule. If necessary, use it again.
Slimsta said:
for #1
the rule states:
"If the expression
what about
L'Hopital's Rule doesn't apply to these indeterminate forms. For the first one, the usual strategy is to let y = your expression, and then take the log of both sides. That will typically give you a product that you can rewrite as a quotient that is one of the two indeterminate forms [0/0] or [infinity/infinity], and then use L'Hopital's Rule. For the second one, you can sometimes rearrange things to get a quotient on which to use L'Hopital's Rule.
Slimsta said:
i know that for
Sort of.
[tex]\lim_{x \rightarrow 0}\left[ 1/x - 1/sin(x)\right][/tex] is an indeterminate form of this type.
Sort of.
oh i get it now.
so #1 would be lny = 1/3 ln(1+3x)
and after solving i get 'infinity'
for #3 it is 2/e^infinity ==> 0
so #3 would be 0
im i correct?
and what if i have a question like this:
[tex]$\displaystyle \Large \lim _{x\to \infty}(\sqrt{x^2+x}-x)$[/tex]
i get [tex][\infty - \infty][/tex]
now how do i use [tex] \lim_{x \rightarrow 0}\left[ 1/x - 1/sin(x)\right][/tex]?
would it be, (sinx-x)/xsinx and now apply the rule f'(x)/g'(x) ?
#1 is still wrong, but #3 is right, so now you have two out of the three of them. I'll talk about #1 at the end of this post.
For this problem
[tex]\lim _{x\to \infty}(\sqrt{x^2+x}-x)[/tex]
multiply by 1 in the form of [sqrt(x^2 + x) + x]/[sqrt(x^2 + x) + x]. That will give you a quotient that might be in a form so that you can use L'Hopital's Rule.
For #1, let y = (1 + 3x)1/x
Take the log of both sides : ln y = ln[(1 + 3x)1/x]
Your result of 1/3 ln(1 + 3x) is incorrect. What should you get?
Notice that there is no limit process going on. After a while, we'll bring limits back in.
For this problem
oh that was my mistake.. for #1 i will get 1/x ln(1 + 3x) and since 1/x is 0 that makes the whole thing 0.. so the final answer is 0.
for the question
i get x/(sqrt{x^2+x}+x)
from there if i use the rule, i get 1/(0.5(x2+x)-0.5*(2x+1)+1)
would that equal 0? because 1/infinity?
In fact, the limit in your last problem is 1/2,not 0, so sorry to burst your bubble.
You don't need L'Hopital's Rule for this problem.
[tex]\lim _{x\to \infty}(\sqrt{x^2+x}-x)~=~ \lim _{x\to \infty}(\sqrt{x^2+x}-x)\frac{\sqrt{x^2+x}+x}{\sqrt{x^2+x}+x}~=~\lim _{x\to \infty}\frac{x}{\sqrt{x^2+x}+x}[/tex]
Factor x^2 out of the two terms in the radical, and bring it out of the radical as x.
[tex]\lim _{x\to \infty}\frac{x}{x\sqrt{1+1/x}+x}~=~\lim _{x\to \infty}\frac{x}{x(\sqrt{1+1/x}+1)}~=~ 1/2[/tex]
In the next-to-last step you can cancel the x in the numerator with the x in the denominator, leaving you with 1 in the numerator and and expression that approaches 2 in the denominator.
For #1, you're closer, but no cigar, and also the limit is not zero.
If y = ln(1 + 3x)1/x
ln y = (1/x)*ln(1 + 3x)*3 -------chain rule!
= (3*ln(1 + 3x))/x
This is true for all reasonable x (i.e., x > -1/3), so it's also true in the limit as x gets large without bound.
So lim lny = lim (3*ln(1 + 3x))/x with the limit taken as x gets large without bound, in which case both numerator and denominator get large without bound, so this is the indeterminate form [infinty/infinity].
See if you can finish this off. Here's what you need to do:
  1. Evaluate the limit on the right, keeping in mind that this is the indeterminate form [infinity/infinity]. Call this value A.
  2. If lim lny = A, then ln(lim y) = A as well. As long as the function is continuous (the ln function is), you can switch the order of the function and the limit.
  3. Since ln (lim y) = A, what is lim y? Keep in mind that what we wanted all along was lim y = lim (1 + 3x)1/x.
how did you get
"ln y = (1/x)*ln(1 + 3x)*3 -------chain rule!"?
i got ln y = (1/x)*ln(1 + 3x) = ln(1 + 3x) / x
==> f'(x)/g'(x) ==>(3/(1+3x))/x = 3x/(1+3x)
==> plug in 'infinity'
3infinity / 1+3infinity = 3/3 = 1
or if it would be infinity/infinity which means i have to apply the rule again,
3/3 = 1 anyways..
in yours
ln y = (1/x)*ln(1 + 3x)*3 where is the last 3 coming from?
Sorry about that - was thinking about the next step and got ahead of myself.
That should be:
ln y = (1/x)*ln(1 + 3x) = [ln(1 + 3x)]/x
So lim lny = lim (ln(1 + 3x))/x with the limit taken as x gets large without bound, but no you never, never "plug in" infinity. That's what limits are for.
This is how you write it so that you aren't plugging in infinity:
[tex]\lim_{x \to \infty} ln y~=~\lim_{x \to \infty} \frac{ln(1 + 3x)}{x}~~~~\left[\frac{\infty}{\infty} \right][/tex]
[tex]\Rightarrow ln(\lim_{x \to \infty} y)~=~\lim_{x \to \infty} \frac{\frac{3}{1 + 3x}}{1}~=~0\right][/tex]
In the first line above, the [itex][\infty/\infty][/itex] notation is just a reminder to myself that I have an indeterminate form of the type I can use L'Hopital's Rule on. Don't clutter up your work with the f'(x)/g'(x) stuff. If you feel you need to include it, put it off to the side somewhere so that it's not in the main flow of your logic.
In the second line I have switched the order of the limit operation and log function, and have applied L'Hopital's Rule -- that's where the chain rule came in.
The second equation above says that the log of the limit I want is zero, so what is the value of the limit? IOW, ln[lim (1 + 3x)1/x)] = 0, so what's the value of this limit?
==> lim (1 + 3x)1/x)= e^0
==> lim (1 + 3x)1/x)= 1
thanks i got it!
i really appreciate ur help!
Sure, you're welcome. And I appreciate your tenacity. You made a lot of mistakes along the way in this thread, but you hung in there and kept working at it and trying to do better, which is to be admired.
