| Thread Closed |
Using specific heat stuff to find amount of heat(Q=mCT) |
Share Thread | Thread Tools |
| Nov19-09, 02:34 PM | #1 |
Beryllium has roughly one-half the specific heat of liquid water (H2O). Rank the quantities of energy input required to produce the following changes from the largest to the smallest. In your ranking, note any cases of equality. (Use only the symbols > or =, for example a>b=c) (a) raising the temperature of 1 kg of H2O from 20°C to 26°C (b) raising the temperature of 2 kg of H2O from 20°C to 23°C (c) raising the temperature of 2 kg of H2O from 1°C to 4°C (d) raising the temperature of 2 kg of beryllium from -1°C to 2°C (e) raising the temperature of 2 kg of H2O from -1°C to 2°C 2. Relevant equations [tex]Q=mC\Delta T[/tex] 3. The attempt at a solution For (a) I get 25116 J For (b) I get 25116 J For (c) I get 25116 J For (d) I get 12558 J For (e) I get 25116 J So the answer I put in is a=b=c=e>d but it tells me it's incorrect. I found these answers simply by subtracting the final temperature from the initial, multiplying it by the mass and multiplying by the specific heat of water where relevant. For d I used 2093 as my specific heat, and for the rest I used 4186. No clue what is wrong. 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| Nov19-09, 02:40 PM | #2 |
Recognitions:
(e) tricky, to go from water at -1 to 2, you have to heat ice from -1C to 0C and then melt it and then heat water from 0C-2C
Even without knowing the numeric value for the melting energy of ice you know that it takes energy |
| Nov19-09, 07:05 PM | #3 |
Ah that's what I missed. Yeah that would make "e" the one to take the most energy since there would be a latent heat of fusion calculation in there.
Thanks! |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Using specific heat stuff to find amount of heat(Q=mCT)
| Heat and Internal Energy and Heat and Temperature Change: Specific Heat Capacity | Advanced Physics Homework | 4 | ||
| Specific heat capacity, latent heat => ice water steam mixture | Introductory Physics Homework | 1 | ||
| Heat question!??the amount of heat gained or lost by a substance is equal to | Introductory Physics Homework | 8 | ||
| Need to find Density and specific heat of NaOH | Biology, Chemistry & Other Homework | 0 | ||
| Using the Gibbs-Dalton Law to find Specific Heat Ratio | Introductory Physics Homework | 4 | ||
